89 Users Online (92 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> foundation piers
Mon, Feb 18, 2008 at 4:09:57 PM | foundation piers
niro
I am on 9.1 and is trying to show concrete piers on a cellar level along a 12" foundation wall on the perimeter.  The piers are say 4" from the column flanges (see attached image.)
I tried with using concrete columns, but they don't clean up with the foundation walls.  the 2 piers shown are created with actual foundation walls and invisible linework.  But the corner one just won't work right as far as clean up goes.  I tried cut profile but seemed to only allow cutting but not adding beyond the wall boundry.  I don't want to fake it with fill region since it will actually cover part of my structural column.
this seemed like something that should be easlier achived, am I going about this all wrong?
thanks for any help.
Mon, Feb 18, 2008 at 4:26:39 PM | foundation piers
eldados
eldados Avatar
4.5 Stars: 8 Votes
have you tried an in place wall/floor family? see how this joins your wall.
Integrator
KarelCAD
Mon, Feb 18, 2008 at 5:31:35 PM | foundation piers
TJKENNEDY
3 Stars: 2 Votes
Did you try using the Join Geometry tool to join the columns to the wall? It looks like you are trying to creat the same type of pilasters I have. I used 24"x24" concrete columns and ran my walls right through them. I then joined the columns to the wall, and the result is in the image I have attached. Your column material needs to be the same as the wall material or the join will not work properly (I think).
Mon, Feb 18, 2008 at 5:32:54 PM | foundation piers
niro
i did a quick test with creat-in-place but the problems remains (see attached.)
how can I get rid of those lines w/o faking it?  is it even possible?
Mon, Feb 18, 2008 at 5:36:11 PM | foundation piers
niro
TJ,
thats it!  I am going to try Join Geometry out again...I think I tried that but couldn't get it to work.  thanks to you now I have faith!
Incorporating piers into foundation walls
Mon, Feb 18, 2008 at 4:38:44 PM
concrete piers
Wed, Apr 4, 2007 at 5:12:53 PM
Brick Piers
Fri, Jul 8, 2011 at 3:14:27 PM
How can I show concrete piles/piers beyond in a section view
Tue, Sep 20, 2005 at 6:59:33 PM
Continuous footings for the Piers
Mon, Sep 30, 2013 at 12:23:16 PM
Page generation time: 10.9802
