18 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Surface Pattern from family to project.
![Beaucoupnice Avatar](user_avatar/46219.jpg)
![3.5 Stars: 6 Votes](/images/stars_3.5.gif) |
Hi all, I am using Revit 2008 and have generated a door with a mesh-like surface pattern at a particular spacing. When I load it into my project the surface pattern scale differs. All comments appreciated. Many Thanks in advance. Beau
Hi, i don't understand, you create a family door and assign the material to that door and when you load the door to your project the scale of that material is out of scale? do you have the same material in your project before you load the door?
![eldados Avatar](user_avatar/6083.jpg)
![4.5 Stars: 8 Votes](/images/stars_4.5.gif) |
this is wierd but you might have the material already in your project, go into the material settings and see if the parameters are the same or if you have 2 of that materials...
Surface Pattern |
Mon, Jul 11, 2011 at 3:26:14 PM
voronoi surface pattern |
Fri, Jun 24, 2011 at 2:14:03 PM
Surface pattern to Topo surface |
Mon, Aug 19, 2013 at 10:50:10 PM
Surface Pattern Not Transferring to Model |
Fri, Jun 1, 2007 at 1:28:52 PM
Surface pattern |
Mon, Sep 10, 2007 at 11:18:01 AM
Members: | 2018072 | Objects: | 22948 | Forum Posts: | 152217 | Job Listings: | 3 |
