Forums >> Revit Building >> Technical Support >> overhead lines
6 Posts No Rating |
Hello, I have overhead detail lines. I want them to appear above walls/doors/anything the model. Does anyone know how to 'send it to front'? Any help appriciated! vf
11 Posts No Rating |
if I understnad you correctly, you can turn on the RCP overlay and use linework to assign lines you like to see on your plan. in this case perhaps hidden line to represent overhead lines. after you assign the line you will then turn off the overlay and the hidden line will stay on. warning: the overhead lines are the actual objects, so be careful when you move or delete them.
6 Posts No Rating |
Hey Niro, Thanks for the response, but I guess i mis-communicated what I'm trying to achieve, The model lines that I create appear underneath actual 3 dimensional objects (walls, doors, etc.), I want the model lines to appear above these objects. Thanks for taking the time (anyone!) vf
The model lines will have to be created on a plane that is at the level you want them to be.
6 Posts No Rating |
Thanks both of you guys, I got it working at the help of you guys. Thanks again!
" if I understnad you correctly, you can turn on the RCP overlay and use linework to assign lines you like to see on your plan. in this case perhaps hidden line to represent overhead lines. after you assign the line you will then turn off the overlay and the hidden line will stay on. warning: the overhead lines are the actual objects, so be careful when you move or delete them. " How do you get an "Overlay" to turn on? I try to go and turn on the RCP Underlay but my RCPs don't show up inthe view properties. How do I get the RCP on or off as an underlay to accomplish what you're explaining? Thanks, Lorne
Denver, CO
Revit Architecture |
nevermind I got it. Select the plan then select RCP under that.
Denver, CO
Roof Overhead Lines |
Wed, Feb 17, 2010 at 8:36:00 PM
Overhead Door Family |
Thu, Nov 1, 2007 at 8:42:53 AM
OverHead Door creation Rev 2009 |
Mon, Jun 27, 2011 at 9:34:37 AM
Porch Rack - best practice? |
Thu, Jun 18, 2015 at 10:58:36 AM
Overlay? |
Mon, Jul 22, 2013 at 12:07:51 PM
Members: | 2118525 | Objects: | 23198 | Forum Posts: | 152309 | Job Listings: | 3 |
