91 Users Online (90 Members):
Forums >> Revit Building >> Technical Support >> Brick Quoins
Does anyone know how to incorporate brick quoins? if so your help be very much appreciated
2 Posts No Rating |
If you only need to show Quoins in an Elevation you can create a filled region with a brick pattern. But if you need to create Quoins in a 3-D view, create a new family and give a material with a pattern, so you can change from brick to conc. if needed. I have included the quoin I always use.
Thanks for your help, but how come i cant load it up from my wall family?
The quoin Tanis provided is a generic model that needs to be placed as a component. You will need to place it, align lock copy as required the same as any other Revit component.
Tom
Post edited on 2005-03-10 11:26:29
Post edited on 2005-03-10 11:26:56
Thanks
Model Pattern Not Moving Independently |
Mon, Dec 3, 2012 at 1:23:46 PM
Parametric quoins (tutorial video) |
Mon, Dec 12, 2016 at 1:08:29 PM
Adjust Brick veener to move down agianst the brick ledge. |
Thu, Jul 26, 2018 at 2:23:13 PM
Brick Colour |
Mon, Jan 13, 2014 at 9:27:03 AM
brick sill below window on brick wall |
Thu, Mar 13, 2008 at 6:10:23 PM
Members: | 2057620 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
