55 Users Online (51 Members):
Forums >> Revit Building >> Technical Support >> Rayfront or Lightscape
6 Posts No Rating |
Is there an easy way to set up your 3D revit model so that the layers, when brought into AutoCAD are all different eg the window frames can be distinguisged from the glcurseand different glcurse are on different layers. I'm wanting to know this so I can then import the AutoCAD files into Rayfront and Lightscape.\
I suppose im asking if anyone knows how to use Lightscape or Rayfront using a revit model instead of an AutoCAD
Post edited on 2005-03-09 06:47:30
----------------------------------- Matty B |
If you go to File-export/import settings-export lines dwg/dfx, you can see and change the linetype, layers that the objects in your model are exported to, when you export to Autocad. Hope this helps.
Virtual Environment VS. Ecotect |
Mon, May 25, 2009 at 9:52:25 AM
My first project in Revit - what do you think |
Thu, Jan 12, 2006 at 1:12:46 PM
Artificial Lights DO NOT turn on in rendered scene |
Sun, Jul 13, 2008 at 11:03:42 PM
Hardware upgrades and Revit |
Tue, Feb 27, 2007 at 9:26:36 AM
Exterior Lighting |
Fri, Jul 8, 2005 at 5:22:02 PM
Members: | 2017212 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
