75 Users Online (74 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Sweep Problem at roof!
Thu, Feb 14, 2008 at 3:30:54 PM | Sweep Problem at roof!
jmiller
I am having trouble with sweeps. I am drawing a log home and i added a log siding profile to the wall as a sweep works fine until it reaches the roof line where it cut the sweep only vertical i have attached a pdf showing the problem. Let me know if you can help. I am using Revit 2008
Thu, Feb 14, 2008 at 4:07:14 PM | Sweep Problem at roof!
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Hey jmiller,
The reason this is happening is because of the sweep profile. Revit doesn't know that it is suppsed to cut it when it intersects the roof.
You could try using a void extrusion and specify it to cut only the sweep, I would sketch the extrusion out so it begins at the bottom of the roof to give you a cleaner more accurate look.
HTH,
Brett
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Fri, Feb 15, 2008 at 7:26:56 AM | Sweep Problem at roof!
mthurnauer
3 Stars: 2 Votes
This is not exactly a solution to your problem, but a suggestion that would make it go away.  Your roof eave aesthetically, and probably functionally, looks a little thin.  I see that you are in Wisconsin.  Is that where this project is located?  If so, I would assume that you are required to have a relatively high R-value for your roof construction and you may maybe a heavy snow load?  The thickness of your roof looks like it is 5 or 6"  I would think you would want to make the roof thicker so that it can 1) have enough visual weight to stand up to the heavyness of the log walls and 2) it may be structurally necessary.  The point of this is if your roof were thicker, then the squared off ends of your log profile would be hidden inside of the roof. Just food for thought.
Fri, Feb 15, 2008 at 10:55:07 AM | Sweep Problem at roof!
jmiller
Thanks for the replys i have tried both ways and the only one i can get to work is makeing the roof thicker, or am i doing something wrong with the void extrusion, done it before but it dosn;t seem to work this time! anymore ideas would be great!
Sat, Feb 16, 2008 at 8:30:32 AM | Sweep Problem at roof!
mthurnauer
3 Stars: 2 Votes
After you make the void extrusion, you need to select the cut geometry button.
Sweep problem
Wed, May 21, 2014 at 9:21:17 AM
Profile Sweep over Roof Cricket [ 1 2 ]
Fri, Sep 7, 2012 at 12:47:32 PM
27
Roof
Tue, Nov 27, 2012 at 5:04:57 AM
Curved roof with sweep?
Fri, Jan 9, 2009 at 5:26:11 PM
host sweep not working in R2009 when roof fascia option used on ridge and hip li
Sat, Sep 26, 2009 at 10:07:01 AM
Page generation time: 0.9619
