108 Users Online (107 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Sloped Roof
Thu, Feb 14, 2008 at 11:49:46 AM | Sloped Roof
AlexDring
1 Stars: 1 Votes
How do i create a sloped roof?  I have a linked arch model and i cant seem to figure out how to get my sheathing to match his slope
Thu, Feb 14, 2008 at 12:53:56 PM | Sloped Roof
MCribb
Under the "architectural" tab is the roof command which has a flyout for "roofs by footprint" etc. In a plan view at the level at which the roof will go, draw roof using 'lines' or 'pick walls' or whatever is easiet, just remember to have the "define slope" button checked before creating. Each roof edge will then present its self with a 'slope' symbol, at which point you can click on that and adjust the slope for each edge. The default is a 30 degree slope. Then pick 'Finish Roof' and it is created. look at an elevation to check slope. If wrong, highlight the roof and pick 'Edit' and you can adjust the slope or the roof outline again (purple lines). Good luck!
adding crickets to a sloped roof structure
Mon, Oct 16, 2017 at 9:28:30 AM
Metal roof deck on sloped roof
Wed, Oct 21, 2009 at 3:33:18 PM
Problems with Sloped Glazing Roof
Thu, Jun 26, 2008 at 11:00:26 AM
Double sloped hipped roof
Mon, Jun 27, 2011 at 2:18:56 AM
Roof to follow sloped structural steel
Wed, Sep 22, 2010 at 4:11:17 AM
Page generation time: 1.7645
