150 Users Online (149 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Changing .rte template midstream
Thu, Feb 14, 2008 at 11:08:20 AM | Changing .rte template midstream
eman3693
New Revit user (Revit 200Shadey.  I have not set up my own customized template yet, and I keep forgetting to start a project using the commercial and/or residential template.  The default template does not contain some of the standards that the others do (ie; commercial stair templates).  Is there a way to update the default template to the commercial template, or a custimized template?  If not, what is the best option.  I assume the standards are stored someplace and I can import the specific item, but I cannot find it.   Thanks
Thu, Feb 14, 2008 at 11:35:12 AM | Changing .rte template midstream
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
You can transfer project standards between .rte file and .rvt files when needed.
If you have a project the you are working on currently and need to get some of the information from the commercial .rte file here what to do.
Open up both files. Go into the project (NOT THE COMMERCIAL.rte) and go FILE>TRANSFER PRJECT STANDARDS.
I would hit check none rather than take everything because the defaul.rte has about 99% of the content that the commercail one does.
 Go through the list and check the boxes that you want and bingo.
After you do this, watch for any warings about duplicated content and elements being renamed numerically,
ie. Steel Pan Stair2, Steel Pan Stair3.
If/when this happens just go through the project browser and delete them out. Just make sue that they are not in use or it will delete them from the project.
HTH,
Brett
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Thu, Feb 14, 2008 at 12:12:07 PM | Changing .rte template midstream
eman3693
Worked like a charm.  thank you.
Thu, Feb 14, 2008 at 1:03:47 PM | Changing .rte template midstream
brettgoodchild
4 Stars: 17 Votes
Glad that worked out for you!
Brett
                             ~ Abraham Lincoln
Cannot get the Mechanical-Default_Metric.rte template to load
Sat, Jun 9, 2012 at 2:30:21 AM
Revit Template File from Project file .rvt to .rte
Sun, Apr 28, 2013 at 1:35:39 AM
template (.rte) or project (.rvt) files
Mon, Mar 20, 2006 at 3:16:44 PM
.Rte - View Template Settings - Reset Linked .Rvt Graphic Overrides
Tue, Feb 10, 2009 at 2:19:03 PM
OLD project with NEW template
Fri, May 30, 2008 at 8:27:49 PM
Page generation time: 1.2972
