53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> cut plane?
Wed, Feb 13, 2008 at 2:00:07 PM | cut plane?
mpp0117
I am working on a project with a new first floor conference room (that we modeled in sketch-up and imported into Revit) the conference room is in the middle of a two story floor opening. It has funky angled walls and sloped top (so you can not look down into it from the floor opening above). My problem is: Revit is not cutting thru the conference room when I am on the first floor… when I’m on the second floor plan it is showing the sloped top of the conference (which is correct) but when I am on the first floor I should see the funky angled walls cut thru… but it is showing the same thing as the second floor (the sloped top). Everything else on my first floor is shown right… it’s just this conference room thing. Is this a problem with my cut plane? Can I change the cut plane on a single component?
Wed, Feb 13, 2008 at 2:12:34 PM | cut plane?
Your problem is cuttable families. From the REVIT Help -
If a family is cuttable, the family displays as cut when the cut plane of a view intersects that family in all types of views.
In the Family Element Visibility Settings dialog, there is an option called When cut in Plan/RCP. This option determines if family geometry is shown when the cut plane intersects that family. For example, in door families, the geometry for plan swing is set to be shown when the door is cut in plan views and not shown when the door is not cut.
This option is never made available and is never selected for non-cuttable families. For some cuttable families, the option is made available, and you can select it. For other cuttable families, the option is never made available, but it is always selected.
The following table lists cuttable families and whether the option is made available for that family.
NOTE:Not Applicable means the category is a system family that cannot be made from a family template.
Family Category - Option Made Available
Casework Yes
Ceilings Not Applicable
Columns Yes
Curtain Wall Panels No
Doors Yes
Floors Not Applicable
Generic Models No
Roofs Not Applicable
Site Yes
Structural Columns Yes
Structural Foundations Yes
Structural Framing Yes
Topography No
Walls Not Applicable
Windows Yes
Edited on: Wed, Feb 13, 2008 at 2:14:31 PM
Wed, Feb 13, 2008 at 3:10:23 PM | cut plane?
mpp0117
Is this telling me Revit will not allow me to cut thru my imported conference room model? Not sure if I understand? Sorry if this is a dumb question… I’m still tying to get familiar with Revit. Thanks for your help.
Wed, Feb 13, 2008 at 4:06:23 PM | cut plane?
maranelloboy
3 Stars: 2 Votes
First, check your view range to make sure your cut plane is at the right elevation.  You may need to place a plan region around the conference room and adjust the view range for that independently.  If that doesn't take care of the problem, you may need to recreate the conference room in Revit.  There may be an option to fully explode the Sketch-Up model, but I'm not sure; I've never worked with it before.  To model sloping walls in Revit you can create a generic mass and apply walls to the faces (all those tools are in the Massing toolbar).  Hope I've helped.
Thu, Feb 14, 2008 at 8:08:58 AM | cut plane?
mpp0117
Thanks for your help… however it is still not cutting thru the conference room model. I also tried converting the sketch-up file to and .dwg file and imported that… and still not working. Any other ideas? Thanks again.
Thu, Feb 14, 2008 at 9:32:42 AM | cut plane?
Jerome111
3 Stars: 2 Votes
have you tried creating a plan region around the conference room only and changing the cut plain for the plan region.
This allows the 1st floor to remain at the typical cut plan with the plan region (about the suspended conference room) to be at a different cut plain.
Under the "view" tab go to "new" plan region...box the conference room finish the sketch and then change the view range at the plan region.
Thu, Feb 14, 2008 at 9:59:56 AM | cut plane?
mpp0117
Yes, I did that… and it is still not cutting thru the conference room. I thought it was supposed to be easy to insert Sketch-Up models into Revit? Looks like I need to rebuild the conference room model in Revit. Are other people having problems importing Sketch-Up models into Revit?
Thu, Feb 14, 2008 at 10:08:43 AM | cut plane?
coreed
coreed Avatar
4 Stars: 16 Votes
make sure you create a mass and then import your SketchUp model into the mass, then finish the mass. then if Revit can cut it, it will. there is a tutorial on this in Revit if you need more info.
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Feb 14, 2008 at 11:43:44 AM | cut plane?
I don't know how you did your sketchup model so I can't address that but I ran a quick test with a 3d autocad model and it cuts correctly.  My test was to export a REVIT model to 3d dwg and then import that into REVIT.
I also imported a 3d Autocad model that would not cut. (forklift truck that was posted here)  That model had solids in it.   Perhaps your problem lies there somewhere.
Thu, Feb 14, 2008 at 11:52:22 AM | cut plane?
mpp0117
I got it to work... I needed to create a mass when inserting the SketchUp model… the Revit tutorial “Importing SketchUp Files” was a big help. Thank you for all your help.
Cut Plane display issue
Tue, Oct 11, 2011 at 12:48:43 PM
Would like shadows to appear from above cut plane
Wed, May 2, 2012 at 1:22:45 PM
How to control where the cut plane is for families?
Sun, Nov 22, 2009 at 10:20:00 AM
high windows and cut plane
Mon, Mar 19, 2012 at 10:15:30 AM
Cut Plane as a parameter
Fri, Apr 17, 2009 at 12:37:13 PM
Page generation time: 0.8725
