76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Scheduling the unschedulable
Tue, Feb 12, 2008 at 5:52:37 PM | Scheduling the unschedulable
SergioBee
SergioBee Avatar
The scenario: We have a Room Finish Schedule with the materials called out in their shortened versio (i.e.: CT-01, CT-02, PT-01, etc). Therefore there will obviously need to be another schedule / legend to describe all these materials.
Question: How do you go about scheduling these items. I realize that there is an option of placing the images in a legend, and going that route, but since the images will probably not always print , etc. we would MUCH rather prefer the architectural standard of a schedule. However, I can't seem to find a way to schedule these finishes. I was thinking about a workaround using Keynotes or Tags, but maybe my inexperience with Revit (we're just starting out) is keeping me from getting a proper schedule using those tags.
So... any ideas? Thanks. (We're on RAC 2008 )
Edited on: Tue, Feb 12, 2008 at 5:53:05 PM
Tue, Jan 13, 2009 at 5:41:03 PM | Scheduling the unschedulable
cobblea
We are facing the same situation on a job we are doing.  We have assigned different Materials to have the name PT.01, PT.02, VCT.01, VCT.02, etc. We have material tags that indicate which finish starts and stops in certain locations, and the tag displays the names nicely (VCT.01-->|<--VCT.02).
Now if we were just able to schedule Materials, that would be a help us explain what all the short hand names that appear on the finish plan (and in our room finish schedule). I have looked through the forum, but have been unable to find anyone with a good answer to this.  Perhaps this should go on the wish list? Anyone have ideas for a work-around?
Thank you!
Tue, Jan 13, 2009 at 6:13:11 PM | Scheduling the unschedulable
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
I was able to generate a Material Finish schedule by using the Material takeoff. I had to add some shared parameters to my materials and also had to set up a filter to show only the materials I wanted. It was kind of a long process, but it is possible.
Retaining Curtain Wall Door Scheduling Data
Thu, Jan 8, 2015 at 2:47:08 PM
Wall Scheduling
Mon, Sep 10, 2018 at 8:06:43 AM
SCHEDULING CONDUIT BENDS
Thu, Sep 21, 2017 at 10:06:06 AM
Calculation for Text in Scheduling
Mon, May 30, 2016 at 8:02:21 AM
scheduling structural props of walls or roofs
Sat, Nov 8, 2008 at 12:03:47 PM
Page generation time: 3.5985
