55 Users Online (54 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Structure >> Technical Support >> Goofy arcs with dimansion leaders
Tue, Feb 12, 2008 at 10:15:31 AM | Goofy arcs with dimansion leaders
rwebb0418
Is there a way to to change the arc leaders for dimensions to either a straight line or two line segments like in AutoCAD?
Fri, Feb 15, 2008 at 4:37:08 PM | Goofy arcs with dimansion leaders
justinblack
Yup!  The way to do this is to pick on your text.  Go into the properties and you will see a toggle for "Arc Leaders".  Uncheck it!  Note that this is an instance parameter.  (You will have to select every instance of text/leaders).
HTH
JB
Sat, Feb 16, 2008 at 7:17:10 PM | Goofy arcs with dimansion leaders
gigils
This is working for text that is solely a text box, but not working for dimensions.  I am not finding this option in the dimension properties box, or under the project settings.
Mon, Feb 18, 2008 at 9:59:01 AM | Goofy arcs with dimansion leaders
rwebb0418
Yeah the closest I've found is the ability to shut off the leader, and then draw it in manually; but then that takes ALOT of effort that really shouldn't be required.
Thu, Feb 21, 2008 at 5:47:03 PM | Goofy arcs with dimansion leaders
Sandoz
1 Stars: 1 Votes
Yes, hit "TEXT" in the design bar and up top you'll see 4 options in on the toolbar for adding just text, a leader w/ 1 line seg. and text, a leader w/ 2 line segs. and text, or an arc'd leader and text.
Those options don't appear however unless you start the "text" command 1st.
Fri, Feb 22, 2008 at 9:49:13 AM | Goofy arcs with dimansion leaders
gigils
again, that is for text only, not dimensions.  but, thank you for taking the time to try and help.  rwebb0418, i think we are stuck with the goofy arcs.  boss is not going to like this.
Fri, Feb 22, 2008 at 10:01:57 AM | Goofy arcs with dimansion leaders
rwebb0418
I saw a demo of 2009 and unfortunately the arcs are still there in dimensions, but at least you can input something other than the dimension now in 2009.
 Maybe we can hope for line segment leaders come 2010.
Fri, Feb 22, 2008 at 1:44:33 PM | Goofy arcs with dimansion leaders
Sandoz
1 Stars: 1 Votes
Oops, my fault.  I have a patch on one eye.
Not realy.
Leaders moving_Annoying
Fri, Jan 20, 2012 at 7:37:31 AM
Multiple Keynote Leaders
Wed, Sep 24, 2008 at 1:27:59 PM
Multiply Leaders with Keynotes!
Thu, Nov 1, 2007 at 8:25:03 AM
Can you define patterns using arcs?
Sun, Apr 30, 2006 at 7:23:28 PM
Better Leaders For Dimensioning
Wed, Nov 24, 2010 at 7:52:58 AM
Page generation time: 0.2315
