Forums >> Revit Structure >> Technical Support >> Additional information in Schedules
6 Posts No Rating |
So I've been looking through all the posts about schedules and I'll be damned if I can find the information I'm looking for. In the attached BMP called AB Sched, it shows how our AutoCAD schedules are set up with additional merged cells at the bottom of the table providing additional information directly rellated to that schedule. We're trying to mimic this in revit and the second BMP attached shows our closest approximation. Is there away to add additional rows to the bottom of the table so that we can add in "general notes" about the schedule?
REVIT's schedules would be great if they allowed us to add cells at will like in excel but since they don't I use a work around. For schedules like this, I format my schedule without cell lines. I then draw all of my lines on my drawing sheet and add text accordingly. Sometimes I even turn off the scedule headers and add my own on the sheet. Of course this means that the scedule / border is no longer automatic so I have to verify that addition lines were not added or subtracted before outputting.
6 Posts No Rating |
Ugh... that's exactly the answer I was hoping I wouldn't get. Well maybe things will change come RST2009. Thanks anyway
20 Posts No Rating |
Q1: I need to create a schedule for a Model Room - i will like to create a schedule with everything in it. The schedule should have plumbing fixture, furniture, materials,... Can someone help me? Q 2: When creating a Plumbing Schedule i will like the Material & Dimensions to show how can i do this task?
36 Posts No Rating |
gee, it was only a year ago that you asked this, so i'm sure you've come up with a solution that works for you... but my solution for this was to just create a drafting view for the notes - applied to the sheet under the schedule without a view tag.
Schedules for Information In Schedules HAHA |
Mon, Feb 13, 2012 at 12:08:12 PM
Schedules: Ie Door schedules! |
Fri, Jul 11, 2014 at 2:58:22 PM
SCHEDULES |
Tue, Feb 24, 2009 at 2:37:56 PM
11
Schedule - share information between |
Thu, May 14, 2009 at 9:23:28 AM
Door Schedules - Revisions |
Fri, Nov 12, 2010 at 4:10:09 PM
Members: | 2114638 | Objects: | 23192 | Forum Posts: | 152319 | Job Listings: | 3 |
