41 Users Online (40 Members):
Forums >> Revit Building >> Technical Support >> Can't Select Wall
19 Posts No Rating |
I am using Revit Architecture. I am utilizing a number of different phases. For some reason, I have a wall that will no longer allow itself to be selected. Other walls in the same phase can be selected. Any ideas?
if you are using design options, you must either be in the design option to select the wall or uncheck "active option only" in the design bar.
yes, it was the design option. thanks
3 Posts No Rating |
Awesome. Thanks jterrell. Your solution makes a wall (or other component) selectable. However, I am still having trouble cleaning up joins and whatnot between existing and new construction. I'll look to other threads for that answer.
Edited on: Mon, Aug 8, 2011 at 3:19:45 PM
Stacked Walls - Can't select wall layers |
Mon, Jun 24, 2013 at 3:14:41 PM
Not able to select a wall. Help! |
Mon, Jun 30, 2008 at 12:36:09 PM
Can't area select a custom family? |
Wed, Oct 9, 2013 at 2:27:34 PM
Can't select model lines |
Wed, Jun 14, 2017 at 10:33:16 AM
Can't select Wall and Grid - Not Design Option fault |
Thu, Jun 20, 2013 at 10:30:13 AM
Members: | 2017222 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
