27 Users Online (24 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Tips & Tricks >> Array within Family
Mon, Feb 11, 2008 at 1:52:21 AM | Array within Family
JustinT
Thought this might be useful to any new Revit users creating Families with arrays...
http://www.revitup.co.za/main/page_tips__tricks_families__arrays.html
Justin
Wed, Mar 5, 2008 at 8:46:07 PM | Array within Family
eldados
eldados Avatar
4.5 Stars: 8 Votes
Thanks for that,  just a couple of comments Smile
1- I would use the Beam system to array thos rafters, much simpler and can be used for many applications.
2- Check out Mr Spot's Nested array tutorial to a more in depth lesson...
Cheers,
Integrator
KarelCAD
Thu, Mar 6, 2008 at 12:25:39 AM | Array within Family
JustinT
Good point about the Beam System.. I have used this, though I created this little example to show how components can be manually arrayed i.e the same principles for this family can be used to create shelving, bookcases etc.
 Thanks
 Justin
Family w/ Array Formula
Fri, Mar 23, 2007 at 9:29:37 AM
Radial Array in a Family
Mon, Apr 11, 2005 at 8:56:12 PM
Array Parameter within Family
Thu, Aug 7, 2014 at 8:25:09 AM
Parametric Array Constraints
Tue, Jul 2, 2019 at 7:00:45 AM
Editable nested family inside parametric array host family
Wed, May 19, 2021 at 8:05:22 AM
Page generation time: 4.1295
