88 Users Online (87 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Modifying Spot Elevations
Thu, Feb 7, 2008 at 4:41:41 PM | Modifying Spot Elevations
JenniferFPA
I would like my spot elevations to read with the text on top of the line and the elevation under the line? Can I do this is Revit?
Thu, Mar 6, 2008 at 8:33:18 AM | Modifying Spot Elevations
callie
Did you ever figure this out.  I would like to add a label so we could have text on top for things like "finished floor", "top of steel", etc and then have the elevation on the bottom.  When I go into the spot elevation tag family, the label tool is grayed out.  I realize that we can use the regular text in the model to do this, but if I could attach it to the spot elevation it would always be there, move when the symbol moved, etc.  If you were able to figure this out, please post your solution.  I can't find an answer anywhere.  Thanks!
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:12 AM
Spot elevations
Fri, Jul 29, 2016 at 8:01:29 AM
Revit Spot Elevations, Rooms and Color Schemes Problem
Mon, Jun 24, 2013 at 12:46:36 PM
Revit refusing to use Spot Elevations
Mon, Oct 14, 2013 at 3:47:55 PM
13
rotating spot elevations on plan
Fri, Mar 6, 2015 at 12:14:15 PM
Page generation time: 0.3383
