50 Users Online (49 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Window not showing up in wall?
Thu, Feb 7, 2008 at 10:25:55 AM | Window not showing up in wall?
DevinB
I've put a window in a wall, and it's kinda showing up but the wall hatch still goes through it and the adjoining wall isn't cutting through at all. It looks just fine in the Main Floor Plan, but this is the Furnishings Plan. The walls have been joined using "Join Geometry" and it all looks good in the main floor plan, but not this one. I've checked Visibility Graphics but nothing seems to be out of the ordinary. The Cut Plain is set the same as the main floor plan. What am I missing? What else can I check? Thanks for any help.
Devin
Exterior wall brick showing in window
Tue, Sep 7, 2010 at 12:59:14 PM
Window elements not showing in one elevation.
Mon, Jun 12, 2023 at 7:15:07 PM
Window not showing up correctly in wall?
Thu, Feb 7, 2008 at 10:40:23 AM
Window Swings Not Showing In Elevation
Fri, Nov 2, 2007 at 1:01:48 PM
Door and Window Frames not showing in Elevation
Thu, Dec 17, 2015 at 4:34:07 AM
Page generation time: 8.1620
