48 Users Online (45 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Rendering
Thu, Feb 7, 2008 at 7:37:04 AM | Rendering
Mogee
Hi guys,
I am working on a project that I am yet to render. When i select the Region Raytrace,  the rendering window does not appear and evidently my render is not loaded.
Are there any solutions to this problem? As of now I have switch off my machine, rest and resaved the file yet the problem still persists.
Anyone have any suggetions
Thu, Feb 7, 2008 at 2:19:59 PM | Rendering
Make sure your Accureder sesource is set under options/rendering - the path should be something like REVIT 2008 CONTENT\Rendering\AccuRenderRedist
Fri, Feb 8, 2008 at 1:35:16 AM | Rendering
Mogee
I have checked the link and it is set to the exact same one.
 the other thing is if i copy my project to a new file I am not able to copy the user materials that I have used. It renders but I have to relink all the materials to the program, now with a multi purpose development that seems a daunting task.
Still cannot render the original file. Any thoughts on that change inthe wormworks?
Fri, Feb 8, 2008 at 7:33:34 AM | Rendering
First, make sure the resource link is real...  that the file is really there.  Perhaps it was not installed correctly.
Second, also under this same tab is where your AccuRender library is set so if you have added new materials to a project's library and want to use that library in another project, you will need to set that here.
Realistic Rendering [ 1 2 ]
Thu, Aug 4, 2011 at 2:30:37 PM
25
2 Days Rendering...38% Complete 2009 Slow Rendering [ 1 2 ]
Wed, May 13, 2009 at 7:36:39 AM
22
09' Rendering Issue
Wed, Jun 3, 2009 at 4:22:51 PM
11
Going from Rendering in RA 2008 to Rendering in RA 2009
Mon, May 11, 2009 at 4:32:50 PM
help with rendering!
Wed, Aug 10, 2016 at 10:47:17 PM
Page generation time: 0.5859
