46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> Spiral stairs that follow a conical wall
9 Posts No Rating |
Here's a doozy... I need to make stairs that follow the exterior of a conical (tapered) circular tower. The base interior radius is 5.5' and the top interior radius is 4'. The stairs need to be 3' wide. My guess is that I will have to make an in-place model, as I don't think this is possible as a 'stair' model component. Either way, it seems like a huge pain in the rear. (RAC 200 Any ideas?
Should not be a problem - I just modeled one that uses a series of tagent curves to approximate a spiral.
9 Posts No Rating |
ah i see.. that makes sense... so you just worked your way up and in, one stair at a time?
You can do it one tread or more. It's up to you. It partly depends on if you want the same distace between each tread at the minimum side or if you want the treads spaced equal angle radially. Th easy one is equal angle. Just array some guide lines then use those along with a correct spiral.
9 Posts No Rating |
thanks!
Spiral Stairs around a Central Post |
Sat, Apr 16, 2011 at 9:27:29 AM
Railings for spiral stair is not following stair incline |
Mon, May 20, 2019 at 8:36:25 PM
conical roof generation |
Wed, Oct 25, 2006 at 6:58:28 AM
Joining a conical roof to a gable roof or other rectangular roof |
Tue, May 28, 2013 at 9:29:25 AM
Spiral Stairs |
Fri, Jul 4, 2008 at 1:34:57 AM
Members: | 2017200 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
