129 Users Online (128 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> question with ref plane
Mon, Mar 7, 2005 at 7:04:49 AM | question with ref plane
jiaoyanbing
when ref plane don 't display in hidden line in all views ,how should i select it?
Mon, Mar 7, 2005 at 2:40:12 PM | RE: question with ref plane
auxblade
Quoting jiaoyanbing - 2005-03-07 07:04:49
"when ref plane don 't display in hidden line in all views ,how should i select it?"
Go to the view (typ. an elevation) where the ref plane should be and you ought to be able to see it appear when you mouseover the hidden line. Sometimes it takes a sec to find it. Make sure that it would be seen in this elevation.
Post edited on 2005-06-13 03:59:33
Mon, Mar 7, 2005 at 5:33:04 PM | RE: question with ref plane
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Using V7.0, you need to check that the 3D extents intersect the Plane of the view and it must also intersect at right angles in order to display. HTH.
Wed, Mar 9, 2005 at 3:23:45 AM | RE: question with ref plane
jiaoyanbing
thanks both of you for your response.what i ask is that if ref plane is not at the right angle,for example ,i creat a ref plane in the floor plane view ,then in the any elevation view rotate it 30 degree, so the ref plane is not at the right angle ,and in the all views,it can not display in hidden line.so how can i do to select it?
Copy / Move to a new Ref Plane
Wed, Feb 2, 2011 at 4:53:16 AM
12
Revit Arch 2009: Cannot align circular solid extrusion to ref plane
Thu, Aug 25, 2011 at 3:03:35 PM
how to change defined ref planes in a family
Mon, Apr 18, 2011 at 2:07:00 AM
Locking a Inseted Family To a Ref Plane
Tue, Jun 10, 2008 at 3:12:07 PM
Workplanes
Wed, Jan 19, 2005 at 6:45:58 PM
Page generation time: 0.7124
