Forums >> Revit Building >> Technical Support >> Filled Region <invisible lines> overlapping and hiding surrounding lines
Mon, Feb 4, 2008 at 10:26:21 AM | Filled Region <invisible lines> overlapping and hiding surrounding lines
hyoctane
I have begun adding the final details to my CD drawing set and I have come to a point that I think AutoCAD is superior. The filled region is not working for me! This is my dilemma: I am attempting to apply a filled region in a plan view and section. Every time I draw my hatch (filled region) I use the <invisible lines> and it seems to be overlapping on my walls hiding them. I have tried to send the filled region to back and the <invisible lines> are still hiding the adjacent walls/lines/etc.
 Any help here? Thanks!
Mon, Feb 4, 2008 at 10:32:57 AM | Filled Region <invisible lines> overlapping and hiding surrounding lines
Invisible boundry lines for filled regions that are in the same location as other lines will hide them.  Your choices are:
- change your boundry lines to the lineweight you want. (You can mix them as you need to.... some invisible and some other linetypes - weights)
- use invisible lines but keep your filled region short of hiding your other lines.
Mon, Feb 4, 2008 at 10:41:34 AM | Filled Region <invisible lines> overlapping and hiding surrounding lines
hyoctane
Thanks for the quick response. Seems like a workaround for a shortcoming on Autodesk's hands. The filled region command seems archaic at best with how advanced and "smart" Revit is.
/rant
Visibility of Filled Region Boundaries over walls
Wed, May 24, 2017 at 1:54:59 PM
Tracing filled regions with linework
Tue, Mar 3, 2009 at 10:24:52 AM
filled region pattern color changes when drawing scale changes
Thu, Apr 14, 2016 at 7:32:06 AM
annotation family with lines on top of a filled region
Wed, Mar 25, 2015 at 6:29:23 PM
Filled Regions
Thu, Jul 19, 2007 at 2:42:06 PM
Page generation time: 3.5330
