Forums >> Revit Building >> Technical Support >> Inserting backround photo into perspective view
Hi, How do you insert a background photo into a perspecive view?
----------------------------------- VND |
19 Posts No Rating |
Its easy.. Select rendering tab. Then select settings. Then enviroment. Select background image. Once selected it goes to a select bitmap option (search computer for picture) . Once you find the picture you can adjust its location withen the view port. Say OK and OK....Thats it... Hope I was a help... TRUEVISIONS JED
Hmmm... tried that, but the photo only appears when i do a raytrace... how do i get it to appear in normal model view so that i can stretch it to correct scale?
I am not possitive but I dont think that it is possible.. See if others know...Maybe ask Admin. TrRUEVISIONS
1 Posts No Rating |
I believe the best thing to do is insert the 3D image into a blank titleblock. Import the background image into the same sheet. Shift things around, apply the right visibility settings, and that should be the closest thing you can do w/ Raster images. This is a very poor work around, but Revit is really weak w/ image manipulation. --Aranya
I'll try the workaround, thanks Aranya...
Plotting Photo-Realism |
Fri, Nov 10, 2006 at 4:04:43 PM
Backround image [ 1 2 ] |
Sun, Jul 27, 2008 at 7:12:51 AM
15
Moving Objects in 3d Perspective View |
Wed, Jul 27, 2016 at 3:52:15 PM
perspective view |
Thu, Feb 7, 2013 at 1:47:35 PM
matching photo settings |
Fri, Dec 10, 2010 at 4:35:49 PM
Members: | 2104014 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
