52 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Repeat Object Within Family/Type
Wed, Jan 30, 2008 at 10:21:34 AM | Repeat Object Within Family/Type
stang
Revit 2008
Is there a way to prgram an object to repeat within a family?
I want to set up a BENCH family, with metal bracket @ 600 oc.  Can I program the bracket to repeat/offset itself when the bench length is changed in a family type?
Help would be much appreciated.  Or I'll just have to do bench with no bracket...
Thu, Jan 31, 2008 at 2:29:58 PM | Repeat Object Within Family/Type
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
You can use the Array tool and create a parameter that will control the number. I haven't had a lot of experience with arrays but I have used them a little. I would suggest that you do a search in the forums for "Array Parameter" or something like that. There is probably a few posts regarding this issue. You can also look up Array in the Revit Help and it will give you some info.
Thu, Jan 31, 2008 at 2:54:56 PM | Repeat Object Within Family/Type
bauhaus1919
bauhaus1919 Avatar
3.5 Stars: 9 Votes
http://www.cadway.com.au/Signatures/CLP/NESTEDFAMILIESARRAYS.pdf
HTH
Thu, Jan 31, 2008 at 3:24:11 PM | Repeat Object Within Family/Type
lpromana
4 Stars: 2 Votes
you can accomplish that with a 3D 2-pick family, the bracket will be a nested family in the bench family, the template for the bench family should be a "generic model line based" how to understand the formula for the array is kinda explained in the tutorials in the nested families tutorial, the one where you do a web truss. I know this is kinda wage let me know if you need added help and I could send you more detailed steps
Fri, Feb 1, 2008 at 9:40:18 AM | Repeat Object Within Family/Type
stang
hey thanks!
I figured out the array function and got myself a L-shape and U-shape bench with automatic brackets.  Very exciting for me... haha..  I assume 2-pick family can't deal with corner condition? CryingPlease let me know otherwise) I will try it out for the straight bench.  Thanks again to all.
In case this is any use to anyone.  here's my U shape bench.
is there any way to transfer family object to instance object or something like
Wed, Jun 1, 2011 at 7:10:56 AM
Family help.... I need to repeat metal studs in my custom wall
Sun, Sep 30, 2012 at 10:25:29 PM
12
Create Roof Family Object
Mon, Nov 21, 2005 at 7:10:43 PM
How to assign a standard family type to an In-Place object?
Tue, Aug 9, 2011 at 5:16:05 PM
Repeat last funtction?
Sat, Aug 6, 2005 at 7:16:58 PM
Page generation time: 12.1447
