57 Users Online (56 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> sheet organization
Fri, Mar 4, 2005 at 4:19:07 PM | sheet organization
aabrmn
is there any way to duplicate a sheet and then change the viewports to other views to keep the same position and size of the previous ones? is it possible to use a grid system to snap on while arranging viewports in the sheet (that's how I used to do it in AutoCAD)? Thank you.
Fri, Mar 4, 2005 at 5:28:25 PM | RE: sheet organization
arnosandoval
5 Stars: 3 Votes
No there really isn't a way to duplicate the sheets with viewports,, you will have to create new ones. You can draw a grid system using drafting lines. And you can draw your lines as invisible lines so they don't print that way you can organize your viewports accordingly. Hopefully that helps.
Fri, Mar 4, 2005 at 8:19:26 PM | RE: sheet organization
aabrmn
ok but how do you snap viewports on those lines? and is it possible in revit to draw lines visible on the screen but not on the print (defpoints in AutoCAD)? thanks for your help.
Sheet Browser Organization
Tue, Nov 18, 2008 at 10:06:04 AM
I wish for more robust browser organization tools
Thu, Jan 20, 2005 at 2:43:46 PM
Project Browser organization . . .Sheet - detail number?
Mon, Aug 29, 2011 at 9:53:14 AM
Shared Parameters for Browser Organization
Fri, Nov 9, 2012 at 11:39:27 AM
Wed, Jan 20, 2010 at 9:02:45 AM
Page generation time: 0.6520
