24 Users Online (23 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Detail view parameter missing?
Mon, Jan 28, 2008 at 5:17:54 PM | Detail view parameter missing?
mje19011
Hi,
I'm new to Revit - had a 3-day training course and am helping out on a project led by more experienced users (but they don't know the answer to this one).
We're adding detail references to all our plan, section, and elevation views. We're doing this by means of the "Section" and "Callout" items on the view menu, which creates the reference tag on the parent view, then we're inserting the detail view thus created onto a dummy detail sheet in order to get the detail/sheet number into the reference tag. So far, so good, but when we finish doing this on an elevation, for example, and then open a plan or section view, many of the detail reference tags show up in unwanted places - evidently because Revit thinks of them as section cut planes existing in 3 dimensions - and we have to turn each one off by individually by picking it and selecting "hide elements" in each view.
This is not practical. We need to be able to add a detail reference to a selected view at will, without having to open up every other view to see if it popped up where we don't want it. I see in the help file there is a description of an instance parameter of detail views that allows you to select "Show in intersecting views" or "Show in parent view only," (sounds like we want the second choice) that is accessed under the Settings menu, Settings > View Tags > Callout Tags... and Section Tags... but when I look, the parameter isn't there. Am I missing something? How can I access this parameter?
BTW the build is Revit Architecture 2008 - 20080101_2345.
I tried to post this in the "Technical Support" forum but the "Start New Thread" link there was inactive.
Thanks,
Michael Evans
Revit 2013: detail number parameter missing
Thu, May 2, 2013 at 7:47:19 AM
Missing Detail Elements
Mon, May 1, 2006 at 12:45:52 PM
Detail Lines missing from view when placed on sheet
Sun, Jan 29, 2017 at 7:16:45 AM
Detail Views - Less detailed?
Tue, Mar 23, 2010 at 8:31:53 AM
fine detail missing on duplicated wall, plan view??
Mon, May 1, 2006 at 8:31:20 PM
Page generation time: 1.7482
