78 Users Online (77 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> area question.
Mon, Jan 28, 2008 at 5:13:31 PM | area question.
Shnail
Hi, i am getting close to wrapping up our first project in revit. the process has been slow, but very enjoyable learning how to do different things. i have screeched to a grinding hault though. the house i am draing is in a certain development that requires us to show how much each finish on elevations is. for example, on the front elevation if we spec board & batten siding, we have to show the percentage of the b&b siding to the total wall area. make sense? so i f the wall area is 600sf,a nd the board & batten takes up 150sf of the total 600, then the b&b is covering 25% of the total area.
in autocad we simply picked points using the area tool, and got the areas of each finish. i am wondering if there is any way to get this done in revit.
thanks for any suggestions, and sorry for any confusion.
Revit user since 2008.
Mon, Jan 28, 2008 at 7:03:48 PM | area question.
TRUEVISIONS
Shnail,
    One thing that you can do is TRACE the areas in the ELEVATION view and then COPY them to the CLIPBOARD and PASTE them into a AREA PLAN VIEW. You can then use GROSS BUILDING AREA to place lines around and calculate. Not fast but it works.
TRUEVISIONS
Mon, Jan 28, 2008 at 8:37:54 PM | area question.
NKramer
4 Stars: 9 Votes
You can do this with schedules assuming that the walls are built properly. You would probably need to add a parameter to walls along so that you can filter the schedule(s) by facade.
It takes a somewhat sofisticated schedule (something that I am still working on), but should be doable with the tutorials and a little help. Post again if you cant figure it out.
Nick
Sun, Apr 26, 2009 at 11:38:20 AM | area question.
Plus
What i do to calculate areas in Elevation view, is to make a "Filled region" (under Drafting tab), and then the Properties of that region will show you the area.
new Area Scheme question
Tue, Jun 20, 2017 at 4:11:50 PM
Rentable vs Gross area, gross area in practice
Tue, Mar 13, 2012 at 11:15:28 AM
Area Schedules and Area Schemes - Revit 2019
Tue, Apr 2, 2019 at 7:41:57 AM
Room tags with area - area not showing up!
Thu, Aug 16, 2007 at 6:54:27 PM
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:04 AM
Page generation time: 1.2369
