95 Users Online (94 Members):
Forums >> Revit Building >> Technical Support >> offset curtain wall grid?
Hi pals, its possible offset the grid of curtain walls to begging the curtain wall without mullion? thanks
I am not sure I understand the question. Do you want to have a curtainwall with a glazed corner with no mullion? If so, yes you can. All you need to do it select the mullions and unpin them. You can then delete the vertical mullions and the curtainwall panels will automatically extend to the edge of the grid. The horizontal ullions will automatically miter around the corner if they are aligned.
If I can create a custom storefront with offset grid, and revit bypass the first mullion I can create the edge faster. is possible? thanks
Curtain Wall Grid Angle |
Tue, Feb 15, 2011 at 2:42:32 PM
Curtain Grid Problems [ 1 2 ] |
Wed, Apr 10, 2013 at 5:57:45 AM
19
Curtain wall grid |
Sat, May 28, 2016 at 9:58:45 AM
revealing hidden curtain grid |
Mon, Sep 8, 2008 at 3:55:02 PM
Curtain Wall Offset |
Mon, Jun 6, 2011 at 10:18:02 AM
Members: | 2017072 | Objects: | 22947 | Forum Posts: | 152211 | Job Listings: | 3 |
