126 Users Online (125 Members):
Forums >> Revit Building >> Technical Support >> Viewports!
6 Posts No Rating |
Hi, Does anyone know how to rotate viewports?
If you right click on the viewport while in a sheet view and go to element properties there is an option to rotate the viewport (only through 90° though). Hope that helps
2 Posts No Rating |
I would create a new view, rotate the view and then drag it onto the sheet. If you don't do that and then rotate what you put on the sheet instead, the name/title of that view rotates 90 degrees too which look dumb and can be annoying...
You can rotate the view while on the sheet without rotating the title. Activate the view, turn on crop regions in view properties, click on the crop regio and click on rotate - you can now rotate the view to any angle. Beaware that the process is backwards from what you did in cad.
2 Posts No Rating |
i think we basically said the same thing.
Edit Visibility Graphics in multiple viewports? |
Mon, Nov 28, 2011 at 1:37:05 PM
Viewports orginizing on sheet |
Mon, Apr 18, 2016 at 10:45:14 AM
Room Plans, Non Rectangular viewports from Revit 2014 and Python Shell |
Thu, May 23, 2013 at 2:28:19 PM
many viewports |
Mon, Aug 24, 2009 at 9:17:12 AM
Revit FBX to 3D Max 2011 causes black or unresponsive viewports |
Fri, Jan 13, 2012 at 11:29:51 AM
Members: | 2057787 | Objects: | 23076 | Forum Posts: | 152250 | Job Listings: | 3 |
