Forums >> Revit Building >> Technical Support >> Window not visible, only opening - Revit 2008
Tue, Jan 22, 2008 at 9:32:23 PM | Window not visible, only opening - Revit 2008
A5Len
I have a drawing in which i have a wall with windows at different heights. The cut plane was origionally at 1200 and the windows over were not vissible. When i adjust the cut plane to be at a higher level, which cuts through the window, it only shows the window opening. Same applies if i try adding a plan region and modifying that.
If i move the window down into the 1200 cut plane zone it shows fine
Any Ideas?
Tue, Jan 22, 2008 at 10:11:42 PM | Window not visible, only opening - Revit 2008
deboddy
5 Stars: 2 Votes
I have found that the plan regions have to encompass a larger area than you would think to show the windows properly. So if you just drag the boundaries out a bit it should display OK without affecting the view of other objects.
Deb
Tue, Jan 22, 2008 at 10:30:53 PM | Window not visible, only opening - Revit 2008
A5Len
Thanks.
I seem to have stumbled on the solution. The default sill height was set at 1950mm above floor level and the defaut cut plane on the plan was at 1200mm. When i changed the default sill height to 900mm, then adjusted the sill heights individually, and added a plan region with cut plane at 2100mm it worked.
 So i think that the default sill height has to be below the cut plane for it to work.
Why Roof Cutplanes are visible in RAC 2008 and Why not in Revit Building 9
Wed, Jul 16, 2008 at 10:34:18 AM
New window in a demo'd opening, in an existing building. HELP
Wed, Oct 24, 2007 at 10:59:34 AM
Having a window problem...plz hlp
Thu, Jan 17, 2008 at 3:40:40 PM
Window Head / Opening Cut
Mon, Feb 10, 2014 at 7:30:59 AM
window opening
Mon, Aug 24, 2009 at 8:03:18 AM
Page generation time: 3.1538
