115 Users Online (114 Members):
Forums >> Revit Building >> Technical Support >> I can't use this component....
I cannot use this wall-based stair lift family (attached file). Whenever I attach it to the wall, it says "Can't make type Stair.... family." This file was taken from the downloads page.
This family had several constraint problems. The main problem was the lifts relationship to the "wall face" didn't allow different wall thickness to be used. This will "blow-up" an attempt to load a problem family everytime !!! (one of the first issues I look for). Another problem was the "lift platform". With so many parts making this element, it really needed to be created as a "nested family" to allow it to move around without blowing apart. It looked like there were some "dead constraints" that didn't affect this basic model from being inserted so I didn't attempt to fix them... maybe you can do this? Hope this helps you. Dan-o
Thank you for your time, Sir. I will try this family that you uploaded and I will also try if i could still fix the previous family.
How can you place a component's width by picking two points? |
Thu, Dec 22, 2005 at 3:42:01 AM
Visibility of component acting up |
Wed, May 7, 2008 at 4:59:08 PM
Model-In-Place Component adhering to plan's view range. |
Mon, Apr 12, 2010 at 12:18:43 PM
revit can't make component stair |
Fri, Jan 8, 2016 at 1:16:21 PM
Can't move component vertically |
Fri, Apr 20, 2018 at 3:22:19 PM
Members: | 2030633 | Objects: | 23003 | Forum Posts: | 152205 | Job Listings: | 3 |
