Forums >> Workflow & Implementation >> API & Third Party Apps >> Render list of views
![5 Stars: 4 Votes](/images/stars_5.gif) |
Thanks for letting me know! glad it worked..
ill add it right away! thanks
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381 |
Hello!
anything to share? feedback? did it work? ![Smile](/images/smiles/smile.gif)
Ciao
Igor
It does work...sort of. :-)
The autosave dialog is stalling the rendering, so next morning it was still rendering the first view.
hello!
this means that they changed the lettering in the program for quick access..
please have a look at this topic and post a screenshot of the second part. (the one referring to the ALT button)
http://www.revitcity.com/forums.php?action=viewthread&thread_id=28368
so i can fix this problem quickly.
Here are the images requested. I hope you can fix it....
thanks! looking into it. could you please tell me what of the 4 checkboxes is causing the program to stall? when it saves the image to the project, when it saves it as jpg, or when it is saving the whole project?
thanks!
also could you please post a screenshot of the stalled app so i see what it is expecting? thanks!
![riarchitect2012 Avatar](user_avatar/343767.jpg)
![4.5 Stars: 25 Votes](/images/stars_4.5.gif) |
Thanks a lot , I am so anxious to try it...thanks again
Your welcome!
Hope RVANL answers so i can fix the problems he found. Please let me know if you find any problems on your end.
Thanks!
Igor
Thank you very much Mr.Igor, I installed v3.1 for Revit 2014...and it is working very well ..This is the most helpful Adds-in I ever used, .I dare to say good bye for"non sleeping nights" waiting for Revit to finish render and manually start another render,thank you again.please accept my best regards.
Nice to hear! ![Smile](/images/smiles/smile.gif)
still all working good? let me know!
Ciao
Igor
I've got a new issue with your add-in.
Last night I tried to render 11 views. This morning when I looked at my computer only one view was rendered and the following message had popped up:
It seems like your add-in wants to save te whole file path wich revit doesn't allow to do. When I removed the path from the suggested filename in de dialogbox It did save the rendered image.
Any clue?
sort of a clue.. what version are you using?
Version 3.1 for Revit 2014.
thank you!
could you please post 2 screenshots:
1 of the plugin with all the settins the same as when you had the above error,
1 of revit, but before you take the screenshot hit the ALT button to show all keyboard shortcuts.
you are on the english version, right?
i cant do it myself because i am on the 2015 version.
