73 Users Online (71 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 2010 classic
Search this ThreadSearch this Thread | Page 5 of 5 | << Previous 1 | 2 | 3 | 4 | 5
Wed, Sep 9, 2009 at 11:50:51 AM | 2010 classic
#61
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
99- are you talking about the classic UI?
please explain..
Wed, Sep 9, 2009 at 11:37:49 PM | 2010 classic
#62
jeremiah77769
1 Stars: 1 Votes
Prophecy, yes unfortunately Autodesk felt the should not include all functionality in the old UI they had so lovingly created. (=P)
 Some functions are not working and, if we don't b*tch enough, will probably never get returned to the functionality they once had. I really hope that 2011 has the option to use either UI as it just shows a lack of initiative IMO that they did such a major change and give you no option at all to keep some, or all, of the interface in tact. All I can really say is at this point 2011 is gonna have to be a very nice piece of software or I'm highly doubting the boss is gonna pay up for the subscription he has now.
Anyways, I will stop with the gripe but sheesh, this program can be a frustrating SOB and the ribbon makes it even worse than it used to be.
On to the future, with the old UI!
Edited on: Wed, Sep 9, 2009 at 11:38:08 PM
Thu, Sep 10, 2009 at 12:07:05 AM | 2010 classic
#63
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
jeremiah-
what do you think is not working with the standard UI for 2010?
besides model lines that we can work around..
and what do you think doesn't work as well as it did
everyone needs to realize that the ribbon is just a program
added on top of what is already there.. that's why the debug.ini
just bypasses the ribbon program..
i am pushing hard for that debug to work for 2011.. and i also
am pushing for them to add any new commands to the standard
UI for 2011..
i'm even saying i'll stay with 2010 permanently if i have to..
join us all in convincing autodesk that we need the standard UI
with whatever new commands there are for 2011.. and we could
use our model lines back too..
Thu, Sep 10, 2009 at 7:56:12 AM | 2010 classic
#64
Prophecy99
Prophecy99 Avatar
^^ Yes when using the old classic UI in 2010 you cannot access multiple trim or extend trim commands.  But that did motivate me to customize the keyboard shortcut commands to work around that but still, those things should be accessible. and one huge thing that was lacking was
- Dimensioning: Once you click dimension The only dimension type available is aligned. You have no way of accessing linear dimension, angular dimension, radial dimension, and arc dimension.
That being sad I had to go back to the retchid slow ace ribbon yesterday and today.
Imagination reveals truths reality obscures.
Thu, Sep 10, 2009 at 1:45:05 PM | 2010 classic
#65
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
99-
how do you get shortcut keys to work with the classic?
Thu, Sep 10, 2009 at 2:01:21 PM | 2010 classic
#66
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
99-
you can get a linear dimension with the tape measure..
that's not worth going to the ribbon for..
there will be support for the native interface with RAC 2011- trust me..
Tue, Sep 29, 2009 at 5:12:55 AM | 2010 classic
#67
YachtieILK
If anyone want to see the full list of disabled commands when running the Classic UI in Debug mode, and how to get the shortcut working see: http://forums.augi.com/showthread.php?t=104982
WYS1WYG:  I certainly hope you are correct, compared to the Classic UI, the Ribbon is so sloooow.
Tue, Sep 29, 2009 at 6:46:14 AM | 2010 classic
#68
Prophecy99
Prophecy99 Avatar
^^ thanks for that post definately checking that out, though i dont want to be stubborn and stay in the past with this classic switch, the ribbon is really slow and Unstable on my machine and i have 3GB.
Instead of Fatal errors, I get complete program termination with no warnings.
Tue, Sep 29, 2009 at 10:01:52 AM | 2010 classic
#69
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
thats becuase your virtual memory is not reallocating, its not your physical memory (RAM).
Try turning off your hardware acceleration. it may help
Tue, Sep 29, 2009 at 12:06:31 PM | 2010 classic
#70
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
the ribbon is fine-tuned a little with
this new build.. 20090612_2115(x64)
we are running about 50 50 revit users
on the classic switch and the ribbon..
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12828862
Wed, Sep 30, 2009 at 7:06:43 AM | 2010 classic
#71
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
YES
 http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13126336&linkID=9243099
Tue, Jan 5, 2010 at 1:29:07 PM | 2010 classic
#72
emgeeo
3.5 Stars: 7 Votes
I found it earlier, but can't find it now....
How do I rename my old keyoardshortcuts.txt file in order to co-exist with my classic interface?
Tue, Jan 5, 2010 at 4:54:54 PM | 2010 classic
#73
TKennedy
4 Stars: 7 Votes
Am I the only one here that actually likes the ribbon more than the old interface?
Wed, Apr 7, 2010 at 7:49:08 PM | 2010 classic
#74
eldados
eldados Avatar
4.5 Stars: 8 Votes
I too hated the ribbon. but looking at 2011, they did a lot of work to streamline it, and it is actually better!!
would not recomend going back to the old UI, some commands won't work and it is better to learn it now, as I'm sure Autodesk is not going to go back to the old one Smile
Integrator
KarelCAD
Thu, Apr 8, 2010 at 9:25:31 AM | 2010 classic
#75
Prophecy99
Prophecy99 Avatar
^^ Good to know they figured out the ribbon in 2011 and revised it.  The 2010 ribbon had its quirks.  I look forward to seeing the new one.
Classic View in 2010
Thu, Aug 20, 2009 at 9:54:55 AM
Revit 2010
Wed, Feb 10, 2010 at 3:23:16 PM
using the mirror comand
Wed, Sep 23, 2009 at 2:04:39 PM
11
Revit 2010 UI Missing Command
Wed, May 20, 2009 at 1:49:53 PM
CLASSIC MATERIALS EDITOR
Sun, Oct 21, 2012 at 6:41:21 AM
Page generation time: 1.4725
