Forums >> Workflow & Implementation >> API & Third Party Apps >> Render list of views
its always posted in the first post at the bottom..
2 big bugs that caused crashes, you should update..
Check out my new Renderlist add-in to render multiple views in sequence overnight! Get it here and remember to leave some feedback http://www.revitcity.com/forums.php?action=viewthread&thread_id=28381 |
I will, thanks Frifer...
you're welcome!
Hello again,
I know it has been a while,I just want to thank Frifer for his efforts, the plugin didn't work in my PC for a long time, but thanks to the perseverance of Frifer it worked at last...now I can have a good night sleep while revit do all the renderings... so thanks again.
youre welcome! nic eto hea that you enjoy it!
6 Posts No Rating |
So I've downoaded the files and followed the instructions. The add-in does show up in Revit, however when I click on it, nothing happens. I'm using Revit 2013 from the Building Design Suite. Am I doing something wrong?
Regards,
Marc Boyer
Hello!
well if you installed it and it shows up i think there is nothing you can have done wrong.. (i think at least..)
you could verify these things:
1) everything is on c: drive (revit and the add in)
2) reinstall .net framework 3.5 and 4
please try these two things and let me know.
also please let me know the language of your OS and your Revit version.
Thanks
Igor
Hello Marc!
any news on your end? did you solve the problems?
bestregards
igor
hello , its this working with revit 2013? and Revit 2014?
Because a tried ont both and non works!!
Thankz
Edited on: Sat, Dec 28, 2013 at 7:29:27 PM
Hi! Thanks for the creating the add-in and offering it to us! Any updates coming our way for 2014?
Edited on: Mon, Jan 6, 2014 at 11:49:16 AM
Hi guys!
2013 should be working fine with the plugin..
i will try to release a 2014 version anytime soon.. but first i have to update to revit 2014 myself. will keep you posted.
Guys sorry for the late update! updated it to 3.1 that should be compatible with revit 2014!
The release for 2015 will be faster!
As promised i released the version for 2015!
Attention! 2015 requires .net framework 4.5.1
Please report any problems!
I can't get your plugin to work. I followed the installation instructions. The external tools icon is present in the add-in ribbon but nothing happens when I click 'Render Views'
I'm using revit 2014 on windows 7.
Any idea?
Hello!
did you get a chance to select the views to render?
do you have some 3D views ready?
did you install .net framework 4.5?
whats the language of your revit?
is the text "render views" grayed out?
also keep an eye on the BLUE text as it tells you what you have to do.
regards
Igor
Edited on: Tue, May 13, 2014 at 9:54:50 AM
