Forums >> Revit Building >> Technical Support >> Window head & Jamb
LOL i'm not allowed to write gla*s!! cause it contains a curse word... I thinking your going to have to add a couple of exceptions Hiroshi!
12 Posts No Rating |
Hi mr Spot,
Brilliant! I'll add the frame and the "transparent component which goes in that frame" (LOL) later today or maybe tomorrow, depending on the free time i'll get.
I'll also try to nest the detail drawing.
When i've done that, i'll post it.
Thanks for for all your help so far.
Not perfect, but here it is... my first window...
Any changes I should make?
Post edited on 2005-01-21 19:04:58
Hi Mr Spot, Do you have any tutorial regardin creating window family. Thank you for your help in advance
Mr Spot does not monito very much anymore. Here is a tutorial that treats the window just like a door frame - wrap around.
Thank you for replying. I am trying to create a window as attached. My problem mostly is how to attach sweep(precast) to the wall, because I should attach a sweep both horizontally and vertically and there is just one workplane. Thanks for help
Window Schedule - Jamb, Head, Sill |
Wed, Aug 7, 2013 at 4:06:58 PM
14
Window Schedule - Head/Jamb/Sill References |
Wed, Jul 15, 2009 at 3:30:03 PM
window jamb wrapping |
Wed, Apr 13, 2011 at 4:26:53 PM
Setting Window Head Height |
Fri, Feb 24, 2017 at 12:16:50 AM
14
head, jamb, sill reference in schedules |
Tue, Nov 1, 2005 at 2:47:55 PM
Members: | 2097061 | Objects: | 23163 | Forum Posts: | 152288 | Job Listings: | 3 |
