Forums >> Revit Building >> Technical Support >> Continued Roof Woes
I think the Key to Making a complex roof is Breaking it up into diffrent roof objects.
Take a look. This was done with many diffrent roof objects.
Post edited on 2006-06-27 08:40:38
you are correct, i always break complex roofs up into smaller roofs based on the different plate heights as one factor
djlandreneau: Could you re-post the first floor plan with rooflines (as drafting lines) drawn over it? Will be really helpfull so we can see how you'd like the roof to look, then we'll draw over them indicating how the footprint should look...
25 Posts No Rating |
I don't have any roof lines other than what is on the elevations.
Yeah, haha but do you remember hundreds of years ago when people used to used dot dash lines to show roof edges, valleys, and hips? If youc ould indicate where they are on your plan (just using drafting lines) then we can easily draw it over for you.
More fascia woes. |
Sat, Sep 17, 2005 at 1:29:00 AM
Design Option problems continued |
Fri, Oct 1, 2004 at 7:53:18 AM
Fascia profile woes....it's only been 2 hours |
Mon, Jan 4, 2010 at 1:16:20 PM
ROOF HIDING ROOF BEAMS! DANGEROUS SITUATION THAT AUTODESK ISN'T ADDRESSING! |
Thu, Dec 6, 2012 at 1:48:10 PM
Visibility woes - Structure shows through ceilings |
Fri, Apr 29, 2016 at 10:48:21 AM
Members: | 2118430 | Objects: | 23198 | Forum Posts: | 152299 | Job Listings: | 3 |
