Forums >> Revit Building >> Technical Support >> Fill Region set to Transparent but printing Opaque
0 Posts No Rating |
We just had this same exact problem in our office.
Turns out it was because the view was set to Wireframe instead of hiddenline. As soon as we changed it to hidden line it woked perfectly.
I know its a few months late, but hope this helps!
Leeunit16,
THANK YOU, THANK YOU, THANK YOU! I was having the same problem and this fixed it!!! Really appreciate it b/c I was already past deadline and ran into this one oddity when trying to print! My office revit guru had given up on fixing this problem, but thanks to your post I was able to fix it!
Thanks again, really appreciate the help!
change to shade mood then print
0 Posts No Rating |
Had similar problem with transparent room fill colors printing opaque. Switched view setting from hidden line to shaded and they now print transparent.
0 Posts No Rating |
I have just sent filled region to the back, well in my case that helped. Even though it did not change anything in working view, it showed correctly in printed PDF.
0 Posts No Rating |
Thanks! Changing from wire frame to hidden line also helped me
Revit 2009 Filled region set to transparent, but is not acting transparent |
Mon, Nov 24, 2008 at 12:40:29 PM
Problem with opaque text showing transparent |
Mon, Feb 24, 2014 at 9:20:11 AM
Opaque background on symbols |
Wed, Feb 3, 2016 at 10:25:15 AM
transparent filled region not showing up over stairs |
Wed, Mar 12, 2014 at 3:39:42 PM
Fill patterns do not print opaque over image files |
Sun, Jul 10, 2005 at 9:56:34 PM
Members: | 2103991 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
