Forums >> Revit Building >> Technical Support >> Format Label Date/ Time Stamp
Hello! Is there any other solution better than putting a mask region on top of the date?
I would like to have the date only without the time!!!!!!
Is this so difficult????
Always check out the similar threads shown below:
You should pay attention to the remove time .....
IS THIS THREAD ABOUT UPDATING THE DATE ON SHEETS AUTOMATICALLY. IM HAVING A HARD TIME TO FIGURE IT OUT. THAT IS WHAT IM TRYING TO DO. UPDATE THE DATE ON MY SHEETS AUTOMATICALLY WHEN I OPEN IT UP AND EDIT IT.
Revit has a built in Date/Time stamp parameter that is available for sheets. We place ours off to the left of the sheet in the binding area. It adjusts everytime you open the sheet. See image
In Windows 10:
Settings >Additional date, time and region settings >Change date, time or number formats >Additional settings >Time >In Long time field delete everything and place a space (spacebar) only (in Revit the space will appear as well, but it will not be visibla as long format) >Ok/Apply
"In Windows 10:
Settings >Additional date, time and region settings >Change date, time or number formats >Additional settings >Time >In Long time field delete everything and place a space (spacebar) only (in Revit the space will appear as well, but it will not be visibla as long format) >Ok/Apply"
Please don’t do this!
It will mess up other applications such as Excel.
28 Posts No Rating |
I can not believe that in 2020 we are still trying to resolve an issue from 2004. I'll ask again incase anyone has discovered anything new. Is there a way to have a date only (no time) that automatically updates? I've tried creating formulas which did not yeild the correct date (this was a suggestion from the autodesk forum). I even tried a masking region and a text box only to find that it will not let me put that on top of the label. Holy crap Autodesk. Get your crap together!
