51 Users Online (50 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Remove constrain?
Mon, Nov 19, 2012 at 3:46:26 PM | Remove constrain?
#16
CDWdavid
5 Stars: 5 Votes
If it is a free form model, you can select it, check "edit in place", then you are able to move in Z-coord.
Mon, Nov 19, 2012 at 7:16:21 PM | Remove constrain?
#17
zuzullo
Ok, here is a file of 2 "cubes", mass elements.
The process to build them was this: http://screencast.com/t/7rTktUYh6
Let me know if you manage to move an element vertically in a 3D view, from one end point to another end point.
Edited on: Tue, Nov 20, 2012 at 6:12:47 AM
Do you wanna SKYPE Revit? Its quicker Smile
Tue, Nov 20, 2012 at 7:52:33 AM | Remove constrain?
#18
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Why is this form being drawn as a mass?  Its just 2 squares.
You cannot snap from one endpoint to another from a 3D view.  Just move it the where you need it in plan view then go to a section or elevation and move it vertically to where you need it.
Tue, Nov 20, 2012 at 7:59:14 AM | teafoe5
#19
zuzullo
Quoting teafoe5 from 2012-11-20 07:52:33
What if its not a Mass element? Is it possible to move any object in revit from point-to-point in 3D view?
A Family withought any constrains?
Any other element?
Tue, Nov 20, 2012 at 8:29:26 AM | Remove constrain?
#20
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Not in the Z direction.  Section or Elevation is your answer to moving those objects
Tue, Nov 20, 2012 at 10:03:01 AM | Remove constrain?
#21
CDWdavid
5 Stars: 5 Votes
If it's only a quick model for preliminary design, then you should use SketchUp.
That's why we are using SketchUp a lot.
One of my wishlist was that we can import SketchUp 3D components into Revit projects.
Sorry, I was talking about Copy and Paste.Edited on: Tue, Nov 20, 2012 at 4:21:44 PM
Edited on: Tue, Nov 20, 2012 at 4:23:36 PM
Tue, Nov 20, 2012 at 10:24:29 AM | Remove constrain?
#22
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"One of my wishlist was that we can import SketchUp 3D components into Revit projects."
You can import Sketchup into Revit
http://formfonts3dmodels.com/2011/08/24/convert-a-sketchup-3d-model-to-revit/
http://whatrevitwants.blogspot.com/2012/02/sketchup-to-revit-with-materials.html
Object not snapping!
Wed, Nov 14, 2012 at 2:56:44 AM
Window wont place in wall of different thickness
Wed, Mar 16, 2011 at 7:19:27 AM
Cant constrain Revit families inside of building
Wed, Dec 10, 2014 at 2:09:37 PM
Can't Constrain
Fri, Apr 27, 2018 at 12:26:19 AM
Strange "constrain" issue when copying.
Thu, Feb 25, 2016 at 6:52:01 PM
Page generation time: 0.3736
