76 Users Online (75 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Spot Levels
Mon, Jul 9, 2012 at 11:38:55 AM | Spot Levels
#16
vhugomg
You can put an spot level on an horizontal detail line inside your section view. Then you select the detail line so the level text turn blue and with this you will be able to type the exact level you want for your stair... hope it works for you.
Mon, Jul 9, 2012 at 3:22:33 PM | Spot Levels
#17
sllana
5 Stars: 2 Votes
ahh what a relief. At last I got the solution. Thank you very much guys, both of you. Both methods work. A huge hug for you.
Wed, Nov 7, 2012 at 9:00:22 PM | Spot Levels
#18
wolvie10002
Hello,
I have a project that I have linked in floor plans. I Cannot put spot levels on the slabs?
I have a simular Project again with Links and I have no problem putting spot levels on the slabs.
I have checked that the slabs are turned on in the views and I can put Spot levels on in 3D views and in Section Views, but not plans.
I have also linked in the plans that are not working in this file into the file where I have no problems and I can Spot level the slabs there.
Is there a setting somewhare causing this issue? I am stumped.
Wed, Nov 7, 2012 at 10:49:20 PM | Spot Levels
#19
Pavan
Pavan Avatar
4.5 Stars: 3 Votes
Check if the view is in 'Wireframe' mode.
Pavan Reddy
Revit Manager
Intelligence is not always knowing the answers, it's always asking the questions.
Spot levels on external floor family
Fri, Aug 17, 2007 at 2:44:14 AM
Spot elevations text on angle
Thu, Oct 18, 2012 at 9:08:10 AM
Spot Elevation vs. Level elevation
Wed, Feb 14, 2018 at 6:13:21 PM
Adding 100' to Spot Elevation
Tue, Jan 31, 2012 at 10:36:29 AM
Setting a manual height for Spot Elevations in plan
Wed, May 27, 2015 at 8:03:12 AM
Page generation time: 0.5413
