Forums >> Workflow & Implementation >> Hardware >> Revit Architecture 201 - License Error
21 Posts No Rating |
If you read my original post. I have been using this program for the past month without any issues, and now it gives me a licsense error. My product key....etc. are all for 2012 and are not the issue. If I am not mistaken, there is some type of coding error or corrupt file that is causing this issue based on the research I have done.
Network and standalone license reference your computer's MAC (Physical) address and the computer name.
Have you done any upgrades or updates to your machine of late? If so, you may need to reauthorize your product info w/ autodesk.
If not, you may consider a clean uninstall (there are white papers for this on Autodesk's site) and perhaps reinstall from a new download or something.
The clean uninstall will remove all related files including corrupted files.
Outside of that, you can check your license life. Not all student versions are perpetual...perhaps it is expired.
Edited on: Mon, Aug 1, 2011 at 5:30:59 PM
I find the time span of one month highly suspicious, because one month is the length of time that autodesk allows its products to be used in a fully-functional trial mode, including saving, before requiring activation.
My guess is that your license never actually worked, and you were, in fact, in trial mode.
Even if I was in trial mode would RAC not promp me that the Trial as expired?
does anyone know of someone I can contact via phone to fix this issue? I am not having much luck on the internet?
Some computers can't find a license |
Mon, Aug 22, 2016 at 4:05:07 PM
Use 'License Tranfer Utility' for Temporary, Telecommuting Revit Drafters? |
Wed, May 12, 2010 at 3:46:55 PM
Portable License Utility (PLU); doesn't open up. |
Thu, Oct 1, 2009 at 4:10:44 AM
As I use the rpc´s from archvision.com in revit? |
Thu, Jul 3, 2008 at 2:07:28 AM
rac2008 portable license utility |
Mon, Jun 30, 2008 at 7:14:26 AM
Members: | 2101388 | Objects: | 23173 | Forum Posts: | 152294 | Job Listings: | 3 |
