79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> Removing pesky sound when objects are deleted.
Fri, Jan 30, 2015 at 2:56:37 PM | Removing pesky sound when objects are deleted.
#16
thellweg
ALL HAIL MATT GROVER
Tue, Aug 18, 2015 at 6:28:37 PM | Removing pesky sound when objects are deleted.
#17
mebrsa
@MATT GROVER
THANK YOU. I OWE YOU MY SANITY.
Fri, Dec 4, 2015 at 2:24:31 PM | Removing pesky sound when objects are deleted.
#18
Almosthip
OMG thanks so much for this info, you saved my sanity. Smile
Thu, Jan 7, 2016 at 10:09:35 AM | Removing pesky sound when objects are deleted.
#19
gregori
@ MATTGROVER, thanks for the deligence in figuring this out. I've been wanting to rid myself of this for 3 years. It works like a charm
Thu, Jan 7, 2016 at 10:22:17 AM | Removing pesky sound when objects are deleted.
#20
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I was not aware that you could use 'backspace' to delete things in REVIT. It is a nice big button maybe I'll start using it.
Tue, Mar 15, 2016 at 4:53:04 AM | MattGroverCo
#21
JeromeLeSueur
Quoting MattGroverCo from 2011-12-22 18:10:36
Hello,
I spoke to our Autodesk dealer. It is not Revit making the sound it was my Windows 7 sound settings. The sound would only happen when i select an object in Revit and hit Backspace. If i hit delete or click on the red X or right click select delete no sound. To fix this issue i went into
Start menu, Control Panel, Hardware and Sounds, Change System Sounds under Sound, in the list of sounds find Exclamation and if it has a speaker by it it is on. Select Exclamation and in the drop down menu below (Sounds) select none. Press ok and try it out. Let me know how it turns out.
Good Luck.
Edited on: Thu, Dec 22, 2011 at 6:11:48 PM"
Thank you so much, you have no idea how that noise was irritating me .... can work in peace now while listening to music!
Sat, Feb 6, 2021 at 8:06:05 PM | Removing pesky sound when objects are deleted.
#22
ndelalio
Thank you MattGroverCo for the solution on the sound chime everytime I selected align in Revit, has been driving me nuts for years!!
You have saved my sanity.
Tue, May 30, 2023 at 3:26:34 AM | Removing pesky sound when objects are deleted.
#23
jamilamkansi
thank you, it worked!
Remove Constraints from Deleted Objects
Tue, Feb 26, 2008 at 4:44:58 PM
Sound Transmission Testing in Revit MEP
Wed, Feb 29, 2012 at 12:27:44 PM
deleting levels without deleting associated objects on it.
Thu, Aug 1, 2013 at 6:20:36 AM
Audio Components
Sat, Aug 14, 2010 at 6:27:42 AM
Sound Isolation Clips
Thu, Mar 14, 2013 at 4:22:18 PM
Page generation time: 0.9904
