20 Users Online (19 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Schedule Parameter formula not showing up
Thu, Oct 28, 2010 at 1:42:57 PM | Schedule Parameter formula not showing up
#16
jshisler
understood, sorry. ill try this out if a get a chance today and report back. thanks so much for helping
Thu, Oct 28, 2010 at 2:18:29 PM | Schedule Parameter formula not showing up
#17
lunchtrayrider
3.5 Stars: 7 Votes
no problem. I find schedule problems fun and I actually usually learn from them so lets figure it out.
I like scooters. and motorcycles.
Thu, Oct 28, 2010 at 3:29:49 PM | Schedule Parameter formula not showing up
#18
jshisler
ok i tried it. still nothing. i think your concept is spot on but i havent given you all teh info. i think this is the problem.
this is an area calculation from generic models.
one of the models have required area, i labeled this not satisfied per your new parameter
the othe model has provided area. i labeled this Satisfied per your new parameter
as  you can see from the schedule above i am showing 20%. that column is a simple calculating parameter in the schedule that takes the required area and multiples it by 20%. this may be why it isnt working?
if(Percentage Required Area < Provided Area, Satisfied, Not Satisfied) is the formula in the results parameter im using and both the satisfied and not satisfied are in the fields also. those text parameters show up in the schedule correctly when itemize each instance.
it is probably somethign really simple im missing.
Thu, Oct 28, 2010 at 3:54:28 PM | Schedule Parameter formula not showing up
#19
lunchtrayrider
3.5 Stars: 7 Votes
your required area and provided areas were fine.  The ONLY (as far as I can see) thing wrong with what you were doing originally was you can't use text in an if then statement.  you MUST only use parameters.  The work around is that you create a parameter with the text you need that you can use there.
you create a text parameter like I said before and name it Satisfied.  then make the text value Satisfied. so
Satisfied=Satisfied
Unsatisfied=Unsatisfied
Result=if(Percentage Required Area > Provided Area, Satisfied, Unsatisfied)
also the calculated values are fine.
your   Percentage Required Area=Area*.2 correct?
 so result really is Result=if((Area*.2)>Provided Area,Satisfied,Unsatisfied)
but revit carries it through as Result=if((Percentage Required Area=Area*.2) > Provided Area, Satisfied, Unsatisfied)
so it works out.
Thu, Oct 28, 2010 at 4:07:24 PM | Schedule Parameter formula not showing up
#20
jshisler
yeah i did create text values for Satisfied and not satisfied. im gonna experiment more
Thu, Oct 28, 2010 at 4:12:20 PM | Schedule Parameter formula not showing up
#21
lunchtrayrider
3.5 Stars: 7 Votes
the provided area you can change manually and then you can see the satisfied/unsatisfied change.
Thu, Oct 28, 2010 at 4:13:57 PM | Schedule Parameter formula not showing up
#22
jshisler
here is it all setup
Thu, Oct 28, 2010 at 4:26:09 PM | Schedule Parameter formula not showing up
#23
jshisler
yeah i think we are on the same page here and  you have helped me think of quite a few things.
 im gonna try a few more things and then maybe ill throw a file up.
 the one major difference im seeing is that the provided area and area in your scenario are in the same family. maybe that has somethign to do with it. each of mine are in a different family. mabye it doesnt matter. im gonna keep playing around.
 thanks so much.
Thu, Oct 28, 2010 at 4:33:57 PM | Schedule Parameter formula not showing up
#24
lunchtrayrider
3.5 Stars: 7 Votes
yea, you've just got to make sure all your wires are plugged in in the appropriate location then you should be good.
Schedule with formula. Yes/no --> Show
Tue, Dec 23, 2014 at 7:34:00 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
One family parameter has formula one has none
Wed, Jun 25, 2014 at 1:05:54 PM
Parameter Formula
Fri, Mar 5, 2010 at 12:09:09 PM
Elevation of receptacle with formula
Wed, Nov 30, 2011 at 12:43:19 PM
Page generation time: 0.7459
