79 Users Online (78 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Tips & Tricks >> coordinates from survey into revit
Thu, Sep 9, 2010 at 1:19:50 AM | coordinates from survey into revit
#16
raephael
hi
the question i started with was how to avoid cad and dwg route,
 i have imported dwgs countour survey-making a dwg countour survey i have not done
i have just spent hours messing with plotting into cad-it comes up in a straight line when i copynpaste points-not sure why -default copy previous z value?
i wanted to stay in the revit package and achieve plotting points
topo import points may be the answer for me:
import as topo /isolate point catogary and join the dots with model line -snap to point
when you  isolate point catagory of topo, effectively you have a point cloud?
i find revit a difficult learning curve and i do not have the skill for dipping into cad max and lisp without a long frustrating delay
martin
Thu, Sep 9, 2010 at 1:36:10 AM | coordinates from survey into revit
#17
raephael
i am trying to avoid autocad route to avoid long delays with my skill level
import topo and isolate point catagory is effctively a point cloud?
snap to points with model lines? visibility parameters of lines within topo edit?
cad plots my coordinates in a straight line-default z value of previous point i.e. z axis/plane disfunctional? for me
this seems to me to be the problem that programmers are still struggling with 3D as a clikndrag package?
so i can blame the tools? i already know i am a bad tradesman?
martin
Edited on: Thu, Sep 9, 2010 at 1:41:50 AM
Thu, Sep 9, 2010 at 9:55:33 AM | coordinates from survey into revit
#18
I think you need to read your Help on Toposurfaces.  Just search toposurfaces.  The process is very easy and not nearly as complicated as what you are trying to do.  After you read these sections, we may be able to help you more.
Fri, Sep 10, 2010 at 4:45:24 AM | coordinates from survey into revit
#19
raephael
hi
i agree with you my lack of knowledge is the problem
but i am not trying to import a point file to do topo
i am trying to plot shapes with coordinate info
same idea as topo but in  super structure
with the coordinate file in the csv format the only import option is topo ?
i adapt topo to my needs
but i will study as suggested   to confirm the above as the only option
thanks for you patience
martin
martin
Fri, Sep 10, 2010 at 6:24:33 AM | coordinates from survey into revit
#20
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
I'm going to say this one more time.
"Import as dwg or dxf"
Fri, Sep 10, 2010 at 8:19:11 AM | coordinates from survey into revit
#21
You write: "...i am trying to plot shapes with coordinate info same idea as topo but in  super structure ..."
That is completely different than your original question.  You can create topography from a points file or from a 3D CAD file that has contours.  If you want 3D objects from a CAD file, then it may be best to create them in CAD and import into a family.
Fri, Sep 10, 2010 at 3:45:24 PM | coordinates from survey into revit
#22
raephael
what you have just said one more time is what i asked to avoid (the first question)
and have managed to using topo in an adapted fashion
no auto cad involved
 a copy of the original quest(1 MO TIME FOR D):
------do i have to go via cad dwg and import????????????
=====or can i plot /import a file(word or notepad) direct to revit?????????
-------but i wanted to go straight into revit with coordinates--not via cadopy of the original quest(1 MO TIME FOR D):
the missunderstanding is of the above question
should i rephrase it?
autodesk like to sell you abox of tissues but when you try to open it you need an addon and when you want to extract a tissue you need the kleenex unraving programme and if you want to blow your nose you need the nosey blow software package
or perhaps youd like the kleenex suite for 10000 bucks which we are still trouble shooting  as you pay
avaniceday
one more time sing it with me D
Sat, Sep 11, 2010 at 5:34:37 AM | coordinates from survey into revit
#23
raephael
Your video will be live in a moment at:
 the above clip:
sample of plotting using topo revit exclusively
avoiding dxf dwg complications and explode restrictions
 the total station generates a .gsi file which then is converted using total station geo office software to .csv (revit topo compatible)
the total station also generates .dxf files but i gave up on it after about 50 attempts(Leica like to hord the info which is spoon fed hoping you wil give up and take a course in what they are withholding)
to use topo the info should be coded to match different parts -in this case branches
to give a different topo surface per code for each part to avoid atrange gestalts-dots incorrectly joined
martin
p s :
is there a topo addon for this(coming soon)
Mon, Sep 13, 2010 at 2:28:55 PM | coordinates from survey into revit
#24
raephael
the tree has grown
Sat, Sep 18, 2010 at 7:02:16 AM | coordinates from survey into revit
#25
raephael
join the dots
Sat, Sep 25, 2010 at 11:16:53 AM | coordinates from survey into revit
#26
raephael
http://www.youtube.com/watch?v=sqIK19ad5FQ
Sun, May 22, 2011 at 1:00:27 PM | coordinates from survey into revit
#27
fosterbill
don't know if this will help but maybe you check out this video I found in an other thread (concerning BIM)
http://www.youtube.com/watch?v=No_1pj0a25Y
Sun, Jul 21, 2013 at 9:51:57 AM | coordinates from survey into revit
#28
raephael
point cloud started shortly after this discussion?
Survey CAD file with large coordinates
Wed, Sep 21, 2016 at 10:36:25 AM
Survey Point and UTM coordinates
Mon, Jun 20, 2016 at 3:50:02 PM
Project base point/ Survey Point
Tue, Nov 13, 2012 at 3:35:36 PM
What is the correct workflow for Referencing drawing to Survey point??
Wed, Apr 29, 2015 at 7:10:51 AM
Toposurface - CSV import to shared coordinates
Thu, Aug 22, 2013 at 2:59:54 PM
Page generation time: 4.1916
