83 Users Online (82 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> any trick in Revit rendering not make it so grey?
Wed, Oct 6, 2010 at 9:09:47 AM | any trick in Revit rendering not make it so grey?
Thread Post Kudo! #16
jche
These settings seem to have worked ok. - white is finally white!
Exposure value: 13
Highlights: 0.35
Mid Tones: 0.65
Shadows: 0.1
White Point: 6250
Saturation: 1.25
White Materials: Self-Illumination at Dim Glow (10.00)
Hope someone will find this useful.
Tue, Jan 4, 2011 at 10:45:42 AM | any trick in Revit rendering not make it so grey?
#17
allisonkapler
@jche - great suggestions I'm definately gona try those settings on an exterior rendering in the future, all my renderings appear very grey, that being said any suggestions for settings on an interior rendering? I'm working with a perspective floor plan that I'd like to get up to marketing quality but there is little contrast in my rendering.
Any suggestions would be great.
Tue, Jan 4, 2011 at 11:15:23 AM | any trick in Revit rendering not make it so grey?
#18
jche
Allison, I would still do it as an exterior rendering since you don't have a roof or ceiling - kind of like taking a photo of a physical model in a daylight. Biggest difference between the two settings (interior vs exterior) in Revit as far as I could figure out is the strength of the exterior light - it is sort of a simulation of the aperture size on a camera lens adjusted for darker interior light which in result make the outside light coming in through window very bright. Try the settings I posted as a starting point and go from there - unfortunately as life has it the same setting won't work as good for every rendering so definitely you'll have to screw around with those for a while to get a result you want. Good luck!
Tue, Jan 4, 2011 at 3:05:01 PM | any trick in Revit rendering not make it so grey?
#19
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Photoshop will always improve a render, too.  I don't invest to much time into tweaking render settings before dumping it into photoshop... they're too twtichy.
Tue, Jan 4, 2011 at 4:19:59 PM | any trick in Revit rendering not make it so grey?
#20
allisonkapler
Thanks the natural lighting settings helps a bit, but any suggestions how to turn off the shadows? They are coming in and making parts of the rendering pretty dark, Ideally if the view was illuminated by natural light but without shadows it would have the best color rendition.
- unfortunately I havent used photoshop before ...
Wed, Jan 5, 2011 at 9:18:01 AM | any trick in Revit rendering not make it so grey?
#21
lunchtrayrider
3.5 Stars: 7 Votes
allison-
what do you mean by shadows? it looks like you have one? interior light and are using the sun for illumination, obviously objects cast shadow.  You might have to crank up the wattage of the interior lights if the sun is on to get the effect your looking for.
I like scooters. and motorcycles.
Wed, Jan 5, 2011 at 9:39:41 AM | any trick in Revit rendering not make it so grey?
#22
allisonkapler
I mean literally turn off the shadows, I want a full illuminated, (not nessesarily accurate to the lighting I've added) just evenly lit, realist rendering that shows the space and the materials, the lighting of this rendering is not the important part as much as showing the contrast of materials and space, but I want it to be illuminated not shadowy and dark. I find the shadows cast by the natural light coming through the exterior windows distracting.
Wed, Jan 5, 2011 at 3:09:07 PM | any trick in Revit rendering not make it so grey?
#23
lunchtrayrider
3.5 Stars: 7 Votes
you could always turn the view to 'realistic' and skip the whole rendering thing altogether.  It would look a lot like sketchup.
you can always render at 3am and turn your exposure way up too.
Color and surface in rendering remain grey
Thu, Jul 5, 2007 at 4:30:06 PM
Rendering Help..! showing up grey
Fri, May 8, 2015 at 1:02:29 PM
2008 Revit_ White walls rendering grey
Thu, Jul 10, 2008 at 11:50:26 AM
Glass Channel problem in rendering, why does it show grey?
Thu, Feb 2, 2012 at 6:54:43 AM
Translucent Existing Phase after Rendering
Sun, Sep 28, 2014 at 7:08:35 AM
Page generation time: 2.0295
