103 Users Online (101 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Grid lines from link outside of crop area
Tue, Jun 21, 2011 at 3:36:18 PM | Grid lines from link outside of crop area
#16
grid
How do I turn off just the linked grid and levels? In VG - Annotation Categories I uncheck levels, but the copy/monitor levels go away as well.
Tue, Jun 21, 2011 at 3:39:54 PM | Grid lines from link outside of crop area
#17
grid
The "Display Settings" of the linked revit file are all grayed out as well, so I am not able to uncheck grids and levels.
Tue, Jun 21, 2011 at 3:41:11 PM | Grid lines from link outside of crop area
#18
You don't turn it off in the main model VG, goto the revit links tab / display settings for the linked model - change that to custom and you will now see the VG for the link.  Turn them off there.
Tue, Jun 21, 2011 at 3:48:02 PM | Grid lines from link outside of crop area
#19
grid
Thanks WWHub - I had made it to the linked files VG but didn't change that to "custom" as well. Got it now.
Palm Springs Architect using Revit LT!
Mon, Jun 27, 2011 at 1:49:59 PM | Grid lines from link outside of crop area
Thread Post Kudo! #20
GUATE17
Employee
Re: Grid lines extend beyond crop area
Got it...The extents of the grids that extend out of the crop region (in the linked file) are set to "2d" instead of "3d". When a grid is set to "2d", the extents are overridden in that view only. Revit assumes that if you set these extents for that particular view (by setting it "2d"), that is what you want to see.To fix it, go back to the linked file, right click on the grid, and select "reset to 3d extents"Joe
Crop region not affecting grid lines
Tue, Oct 19, 2010 at 4:00:29 PM
imported grid offset from crop region
Fri, Sep 19, 2008 at 4:47:10 AM
Multi Segment Grid Line Bubble Issue
Wed, Dec 11, 2013 at 2:52:11 PM
Silly Grid Crop Question
Mon, Mar 14, 2016 at 2:54:20 PM
Masking not working on grid lines
Wed, Jul 22, 2009 at 2:31:18 PM
Page generation time: 2.7230
