123 Users Online (122 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Forums >> Revit Building >> Technical Support >> 3D Sweep?!!?
Fri, May 7, 2010 at 3:43:59 AM | 3D Sweep?!!?
#16
4 Stars: 203 Votes
Look, use "Model Lines" to create the "Skeleton" of the path/object then use "Solid Sweep" and use "Pick Path".... just like that...
Edited on: Sat, May 8, 2010 at 9:11:40 AM
Fri, May 7, 2010 at 7:44:37 AM | 3D Sweep?!!?
#17
coreed
coreed Avatar
4 Stars: 16 Votes
the whole reason this mass thing came about when when doing a path for a sweep is that it's easier to do that when creating the Skeleton and then use "Pick Path", than doing it the way Tyhoon mentioned in his last post. Actually you should use a void mass so there's no chance of the mass being displayed.
but if you want, you do not have to use a mass to create the path for sweep.
Edited on: Fri, May 7, 2010 at 7:45:12 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Can You Flex a Sweep in Components
Mon, Jun 3, 2013 at 2:09:24 PM
Sweep Profiles in Version 9
Thu, Aug 3, 2006 at 2:14:06 AM
How to cut an arch into a sweep
Thu, May 26, 2022 at 4:02:09 PM
Sweep and Sweep/Blend Component
Mon, Apr 23, 2012 at 12:36:53 PM
Wall sweep splitting/joining
Sun, Oct 19, 2008 at 1:29:47 PM
Page generation time: 1.8408
