71 Users Online (70 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Move entire model to a different level!???
Sun, Jan 31, 2010 at 12:39:51 PM | Move entire model to a different level!???
#16
arkoh
Hi Emgeeo
Thanks alot for the video! I really appriciate you trying to help me here!!!
Your solution is kind of the same solution as has been suggested before by others... and having tried the "relocate project" function, using the same shared coordinates, It is not a solution I can use as I have written in some of my previous posts!
Before you do this "specify coordinates at a point", then try to do a terrain, on the original ground level at 0 (the level called "FOUNDATION" in your video!), using points as "absolute elevation" marked as 0. Then do your "specify coordinates at a point", and then try to edit your terrain and check these points on the terrain after you have changed everything to the shared coordinates... they will still be marked as 0!!!!! :-( They will not have changed to the new level with these "shared coordinates" function!! Meaning the "shared coordinates are "only to show!" They do not change the projects coordinate system, so I can start working in real world levels!! Does this make sense!? And if you have a way to change the terrain to follow the shared coordinates, I will be extremely greatfull!!
Mon, Feb 1, 2010 at 2:05:32 AM | Move entire model to a different level!???
#17
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
Arkoh-
well you said "ANYONE" so here i am and i have only been using revit
for five years.. but i'm amazed to see so many revit users asking this
same question about moving buildings and all the answers having to
do with project location and shared coodinates tools that never seem
to be a solution..
i have always built my buildings where i know they will stay put..
because it seems like virtual construction is really what it is..
and in real life you sure won't move a ten story building and you
definitely won't move the earth.. however- i have finally decided
to investigate the possiblity of properly relocating buildings on
a site.. my guess would be the idea of copying the site data to
a new file (separate session of revit) and then also opening a
third session of revit to build a completely new site using the
information in the first separate session.. then when i have
the new site finished and exactly the way i want it to fit the building-
i will link it into my building file..
does this sound like anything to you?
Wed, Sep 1, 2010 at 7:44:34 AM | Move entire model to a different level!???
#18
ab100
Hi Arkoh,
 I see that the last reaction is dated the 1st of february and I can imagine you would have totally rebuild the model by now if you weren't able to find a solution to your problem. Anyhow, I totally understand your situation, because I have the same problem..!
So, I was wandering if you finally found a 'simple' solution to a (at first sight) simple problem....
Wed, Sep 1, 2010 at 9:10:29 AM | Move entire model to a different level!???
#19
ab100
After surching a bit more I found the very usefull thread: 'Changing level elevation for entire model on all floors'
It solved my problem..!
Trying to move entire model to a different level!!
Thu, Jan 28, 2010 at 2:18:31 PM
How to move a single level datum without moving anything in model
Tue, Sep 29, 2015 at 1:53:58 PM
Move half of entire project down vertically
Tue, Aug 4, 2015 at 10:35:42 AM
Wed, Dec 10, 2008 at 7:21:40 PM
Adjusting model from finish floor to subfloor
Wed, Feb 26, 2014 at 2:12:05 PM
Page generation time: 1.0172
