61 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> eyebrow dormer
Wed, Nov 4, 2009 at 5:11:42 PM | eyebrow dormer
#16
hhwse
I have been trying to figure out how to use the blend command but can’t figure it out.  Can anyone point me to a tutorial or give instructions? Thanks for the help.
Thu, Nov 5, 2009 at 3:54:52 PM | eyebrow dormer
#17
tim123
4 Stars: 19 Votes
It's fairly easy.
1. In an elevation view (looking at the front of the dormer) Component, model in place, roofs, give it a name.
2. Click on solid, Blend, Revit asks for a plane.  Select a predefined plane, or 'Pick a plane'.  It doesn't matter exactly where the plane is, you can just select the wall below.
3. Draw the profile of the back face of the dormer.
4. Click edit top and trace over the lines that you drew previously and move them down the relevant amount to create the front of the dormer. Click finish blend.
5. In a perpendicular elevation or section align the front and back to the correct position.  The blend is complete.  You can then create a void extrusion to cut the blend to the roof face.
Fri, Nov 6, 2009 at 8:03:13 AM | eyebrow dormer
#18
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Is this what you are looking for ?
Fri, Nov 6, 2009 at 11:19:48 AM | eyebrow dormer
#19
hhwse
dgcad
That is just what i am trying to do.  So how did you do that?
Fri, Nov 6, 2009 at 12:04:30 PM | eyebrow dormer
#20
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Ok here are two videos that should get you started. My eyebrow arcs and slopes may not be exactly what you use but the process of using an in-place solid blend will be the same.
Edited on: Mon, Nov 9, 2009 at 4:45:54 PM
Roof dormer/eyebrow vents
Tue, May 9, 2006 at 5:54:56 PM
EYEBROW DORMER OPENING
Tue, Jan 20, 2009 at 4:58:43 PM
Free videos or Sloping Eyebrow Dormer
Mon, Nov 9, 2009 at 7:32:59 PM
Single hung Eyebrow's?
Mon, Dec 3, 2007 at 4:22:54 PM
Room bounding in a dormer.
Fri, Nov 8, 2013 at 2:57:00 PM
Page generation time: 0.1984
