Forums >> Revit Building >> Technical Support >> Sketchup to Revit - Layer/Material Problems
Typhoon, I thank you very much for all the help, however condescending as it may have been. Despite the fact that my question was never really answered (which was simply "can you retain materials and seperate layers with a DIRECT sketchup to revit import?) I did manage to figure this out eventually, and the answer is YES. Importing objects from sketchup into revit does NOT require CAD. NO DWG NEEDDED. The way to do it, in plain english, is simple, and is as folows: In Sketchup: 1. Set all materials on seperate layers 2. .*THIS STEP IS IMPORTANT: Paint each different material with a different color: unpainted materials will be consolodated to the "default layer" (layer 0) upon import and will thereforebe un-editible in revit. 3. Save, close. In Revit: 1. Begin a new family, and import the sketchup object. 2. In the material manager, find the material in which the shading appearence matches the paint color that was applied in sketchup. (titled somthing like "Render Material 255-0-0". 3. Change the Render Appearance to the desdired material. 4. Repeat for each material in the object, and render.
Edited on: Thu, Oct 15, 2009 at 4:07:53 PM
Another Tip - use basic colors in sketchup to paint your objects, such as standard blue. This way you can easily locate the Render Material title in Revit, then apply your desired render appearance. Here are three example color codes that are easy: Green- code F01 in sketchup, Render Material 0-255-0 in revit Blue- code I01 in sketchup, Render Material 0-0-255 in revit Red- code A01 in sketchup, Render Material 255-0-0 in revit
hello guys..please see my tutorials...I already teach this...its gonna be easy for you to import SU and change the materials..step by step...
2 Posts No Rating |
I am also having a simillar problem, i wanted to add a structure fro sketchup to revit 2010 so i could place a diagrid on it? how do i that? thanks!
----------------------------------- mambo.harts.u |
"Go to Settings-->Materials....and there you can change all the materials you want, and as an advice, change their names i.e. Render Material ### to whatever other name you want...." ER? i m doing this but wont change the material on the object. I did import the sKP object to a family like generic model i.e. but doesnt work
Not Sure What Revit Can Do?... Find it OUT!!!
“Imagination is more important than knowledge...” -Albert Einstein |
Carru, can you upload your object so I can take a look at it?......
Ok but it is not finish yet!
Edited on: Sun, May 16, 2010 at 10:29:48 PM
97 Posts No Rating |
As a follow up to the above posts, does that mean that all materials that are on our material list named "render # # # #" are from a sketchup model that was imported? I'm trying to clean up and purge our file and want to be sure I can delete all those materials. Thanks in advance.
" As a follow up to the above posts, does that mean that all materials that are on our material list named "render # # # #" are from a sketchup model that was imported? I'm trying to clean up and purge our file and want to be sure I can delete all those materials. Thanks in advance. " probably figured this out by now, but yes, these usually are from sketchup fixtures. you can go ahead and delete them, as long as you haven't assigned render materials to them. if you want those sketchup fixtures to render with materials be cautious when deleting, you may lose the applicable layer which applies to the fixture and be unable to apply a material.
Need Help - Sketchup To Revit Layers |
Thu, Oct 15, 2009 at 11:37:08 AM
Sketchup To Revit Problems *Please Help* |
Thu, Mar 12, 2009 at 9:21:29 AM
Sketchup to Revit material problem [ 1 2 ] |
Wed, Jun 30, 2010 at 11:58:37 AM
26
PLEASE HELP! Revit + Sketchup intol Artlantis |
Sat, Jun 7, 2014 at 6:26:28 AM
13
SketchUp to Revit |
Sun, Mar 22, 2009 at 6:53:33 PM
Members: | 2056535 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
