Forums >> Revit Building >> Technical Support >> Jumpy Options bar with new 2010 Interface
15 Posts No Rating |
Probably have, but have you tried switching which monitor you run revit on? So far that seems to be the issue with some of the others. I just moved it over, didn't have the problem, and then when I moved it back and maximized it went away
This started happening to me after using 2010 for 6 months! Running dual 28" LCD's with an ATI Radeon HD 3800 Series adapter. Tried switching the main monitor, restoring, maximizing, etc. The only thing working for me is to dock it at the bottom. Any new ideas would be appreciated!
1 Posts No Rating |
We have been having this problem since starting to use Revit 2010 in April. It is not a consistant experience between users, but it is happening on all machines. We have machines with nVidia, and ATI, some with dual monitors, some single. Moving the Options bar to the bottom only causes the frames to grow from the bottom instead of the top. We have all Revit updates and subscription packs installed. He rolled back video card drivers, per Autodesks troubleshooting of another graphic issue in Revit 2010, and have since reinstalled the latest ones. Reivt is maximized when in use. None of these measures has fixed the problem. This issue is often occupanied by the manfunction and dissappearance of the Ribbon and/or Quick Access Bar. How do we send in a request to Autodesk manually, this problem doesn't cause Revit to crash, so no report is sent. We used to think it was a problem with our setup, but hearing that others are having this issue convinces me that it is Autodesk's responsibility.
Option Bar in 2010 |
Tue, Dec 8, 2009 at 6:36:30 AM
Revit Arch 2010 Interface Tutorials |
Mon, Dec 21, 2009 at 2:13:19 PM
Custom Options bar parameter |
Mon, Aug 17, 2009 at 4:35:46 PM
Large Monitors and Options Bar "Skipping" |
Thu, Apr 23, 2009 at 3:22:07 AM
Options bar keyboard acces? |
Wed, Nov 11, 2009 at 6:34:22 PM
Members: | 2104005 | Objects: | 23178 | Forum Posts: | 152298 | Job Listings: | 3 |
