65 Users Online (64 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Surface pattern move/align/adjust problems
Fri, Feb 24, 2017 at 3:50:20 AM | Surface pattern move/align/adjust problems
#16
amiamimo
I think i have found the solution.You can create the new material with same appearence and in manage materials you can adjust the surface pattern horizontally and vertically in revit 2017.
Fri, Feb 24, 2017 at 6:15:20 AM | Surface pattern move/align/adjust problems
#17
Just an FYI.   You could always adjust a model pattern horizontally and vertically.  This is not a change in 2017.
Fri, Feb 24, 2017 at 10:53:37 PM | Surface pattern move/align/adjust problems
#18
hugh
3.5 Stars: 4 Votes
>How does one make a model pattern as opposed to a drafting when revit wont let me select model- what am I missing?
You can clone fill patterns wthin Revitwith the free HatchKit Add-In for Revit (from the Revit Exchange) and assign its type as either DRAFTING or MODEL.
Hugh Adamson
www.hatchkit.com.au
Fri, Feb 24, 2017 at 10:53:39 PM | Surface pattern move/align/adjust problems
#19
hugh
3.5 Stars: 4 Votes
You can clone fill patterns wthin Revit with the free HatchKit Add-In for Revit (from the Revit Exchange) and assign its type as either DRAFTING or MODEL.
Edited on: Fri, Feb 24, 2017 at 10:54:24 PM
Hugh Adamson
www.hatchkit.com.au
Thu, Sep 17, 2020 at 10:29:33 AM | Surface pattern move/align/adjust problems
#20
Becraft84
If your wall is pinned, you cannot adjust the pattern. Make sure your wall is not pinned.
Surface pattern wont align
Sun, Nov 9, 2008 at 3:16:04 AM
Unable to rotate/align surface pattern on stairs
Thu, Aug 28, 2014 at 7:29:20 AM
how to change the base line of a revit pattern without use align
Tue, Sep 6, 2011 at 5:03:50 AM
Surface pattern problems
Sat, Jul 23, 2011 at 8:29:46 PM
Surface Patterns
Wed, Mar 4, 2009 at 11:24:15 AM
Page generation time: 3.0323
